[QGIS-Developer] QGIS WCS is requesting FULL dataset?
Andrea Aime andrea.aime at geo-solutions.it
Sun Oct 21 12:19:13 PDT 2018
On Sat, Oct 20, 2018 at 9:58 PM Jonathan Moules <
jonathan-lists at lightpear.com> wrote:
> Hi Lists,
> I'm cross posting this to GeoServer-Users over from QGIS-Dev as the
> current QGIS code seems to be trying to work around a GeoServer quirk
> based on Nyall's code-comment snippet.
> Is there something different QGIS can do to work around the stated issue
> in a better way given I guess requesting a 10x10 Coverage via WCS isn't
> going to be doing the host server any favours?
The behavior described in the comments might be actually happening...
sorry, no time to
look into it right now, we have the JDK11 code sprint incoming and all
spare time is going there.
I checked the ticket tracker, found no bug report about it.
I would be useful if someone could verify, maybe using a built-in demo
dataset.
Fixing it right now might help, but it will take many years before older
versions of GeoServer
out there are upgraded, we get a surprisingly high number  people running 5
years old versions of GeoServer
asking questions on the list.... just saying, even if one rushes to fix it
now, that code in QGIS might
not be lifted anytime soon (but it could be made configurable I guess?).
Also, in GeoServer WCS 1.0 normally uses overviews when available, but of
course the layer
might not have them, or be a mosaic of many files. That said, the WCS being
queried is not a GeoServer,
not sure how it might work.
Finally...  any chance QGIS could be using WCS 2.0 instead? The 1.0 and 1.1
protocols are ancient and pretty clunky,
WCS 2.0 is so much better from all points of view.
In fact, I believe that WCS 1.0 and 1.1 have received little to no
significant maintenance
in GeoServer for the longest time, I'd venture to guess very few care about
them.
WCS 2.0 is instead receiving interest and more care, likely because it has
been chosen by INSPIRE
for raster download services.
Cheers
Andrea
== GeoServer Professional Services from the experts! Visit
http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
(LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181021/80a7c147/attachment.html>
More information about the QGIS-Developer mailing list
