[QGIS-Developer] Rotate or Offset Point symbol: how do they work? Or are they broken?
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Oct 23 04:52:35 PDT 2018
I think also it should, the expressions are supposed to be tested for this.
Le mar. 23 oct. 2018 à 07:11, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi Harrissou,
> I would report it as a bug. I would also expect that an expression with
> just the field in it would work.
> Andreas
> On 2018-10-23 12:58, DelazJ wrote:
> OK. Like usual, it's when you send the message that you get the answer by
> your own. :)
> The problem is an underlying issue where the expresssion "myfield" seems
> to not be the same as "myfield" field ie, instead of selecting the field
> from the data-defined "Field type" menu, I was mechanically opening the
> data-defined "Edit..." expression dialog and selecting the same field. The
> field values are applied to rotation but it's not recognized as a field the
> tool could update.
> Should I report a bug or is it intended/known limitation?
> Regards,
> Harrissou
> Le mar. 23 oct. 2018 à 12:52, DelazJ <delazj at gmail.com> a écrit :
>> Hi,
>> Thanks, Nyall.
>> Le mar. 23 oct. 2018 à 03:06, Nyall Dawson <nyall.dawson at gmail.com> a
>> écrit :
>>> On Tue, 23 Oct 2018 at 03:17, DelazJ <delazj at gmail.com> wrote:
>>> > Hi,
>>> > Any clue on how the "Rotate Point symbol" or "Offset Point symbol"
>>> digitizing tools are expected to work? The docs [0] seems wrong (or
>>> broken?) and whatever I try (including creating a field named "rotation"),
>>> I get a "The selected point does not have a rotation (or an offset)
>>> attribute set." message. And no help on how I could set this attribute...
>> Works fine here. I just data define link it over to an appropriate
>>> field (numeric for rotation, string for offset), and then the tools
>>> work as described.
>> Exactly what I did for the rotate tool. The And doing it again changes
>> nothing:
>> - I thought it had to do with temporary layer, hence switched to shp :
>> fail
>> - swithed field type from integer to double: nothing
>> - I thought it was because i had not saved the file yet (something that
>> would be related to auxiliary storage) then I saved the file: niente
>> - May be it's a matter of qgs vs qgz? Neither
>> I always get that odd message about attribute not set.
>> I'm on Win 10 using master c94eefb6df. What could trigger that?
>> Harrissou
>>> The only thing I can think of is that the docs are a little unclear here:
>>> "near the Rotation option of the highest level (preferably) of the
>>> symbol layers"
>>> This should be set at the "marker" level, not at an individual layer
>>> level. (i.e. click the "Marker" entry in the list, not "simple marker"
>>> and set the rotation there).
>>> Offset can be set at any layer and it will work.
>>> Nyall
>>> > [0]
>>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#rotate-point-symbols
>>> > Regards,
>>> > Harrissou
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181023/24773fae/attachment.html>
