[QGIS-Developer] QGIS crashing on closing
C Hamilton adenaculture at gmail.com
Wed Oct 24 10:13:16 PDT 2018
Andreas,
I frequently have that happen as well and I am on Windows.
On Wed, Oct 24, 2018 at 11:40 AM Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> I am experiencing crashes when closing QGIS with the most recent master:
> When I open QGIS (no plugins enabled, completely empty and new profile),
> and I do nothing (not even a simple project opened).
> I close QGIS and it crashes on closing.
> Am I the only one experiencing such crashes on closing?
> System: Linux Ubuntu 18.04.1 LTS
> QGIS: most recent master, self-compiled.
> Maybe an issue only on my machine?
> Here is what I get in the console:
> QGIS died on signal 11[New LWP 6735]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> 0x00007f1d236456c2 in __GI___waitpid (pid=6744, stat_loc=0x7fff41e120ac,
> options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
> 30      ../sysdeps/unix/sysv/linux/waitpid.c: Datei oder Verzeichnis
> nicht gefunden.
> [Current thread is 1 (Thread 0x7f1d2741e980 (LWP 6734))]
> #0  0x00007f1d236456c2 in __GI___waitpid (pid=6744,
> stat_loc=0x7fff41e120ac, options=0) at
>          resultvar = 18446744073709551104
>          sc_cancel_oldtype = 0
> #1  0x000055cadcbcfffe in qgisCrash(int) ()
> #2  0x00007f1d2359ff20 in <signal handler called> () at
> /lib/x86_64-linux-gnu/libc.so.6
> #3  0x00007f1d25b2e718 in
> QgsCoordinateReferenceSystem::~QgsCoordinateReferenceSystem() () at
> /usr/local/lib/libqgis_core.so.3.3.0
> #4  0x00007f1d25b8ba1d in QHash<QString,
> QgsEllipsoidUtils::EllipsoidParameters>::deleteNode2(QHashData::Node*)
> () at /usr/local/lib/libqgis_core.so.3.3.0
> #5  0x00007f1d23ff46c9 in QHashData::free_helper(void
> (*)(QHashData::Node*)) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #6  0x00007f1d235a4615 in __cxa_finalize (d=0x7f1d26692c00) at
> cxa_finalize.c:83
>          check = 4159
>          cxafn = <optimized out>
>          cxaarg = <optimized out>
>          f = 0x55cadef39e10
>          funcs = 0x55cadef39c60
> #7  0x00007f1d2582e453 in __do_global_dtors_aux () at
> #8  0x00007fff41e13550 in  ()
> #9  0x00007f1d272a8b73 in _dl_fini () at dl-fini.c:138
>          array = 0x7f1d274c0068 <_rtld_global+8>
>          i = <optimized out>
>          l = 0x7f1d2746d510
>          maps = 0x7fff41e12950
>          i = <optimized out>
>          l = <optimized out>
>          nmaps = <optimized out>
>          nloaded = <optimized out>
>          ns = 0
>          do_audit = <optimized out>
>          __PRETTY_FUNCTION__ = "_dl_fini"
> gdb returned 0
> Abgebrochen (Speicherabzug geschrieben)
> Thanks for your help!
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181024/60a30dee/attachment.html>
More information about the QGIS-Developer mailing list
