[QGIS-Developer] Early 3.4 point release?
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Wed Oct 31 00:04:26 PDT 2018
> Bah... feels like *every* major release someone ends up sending an email
like this...
My opinion this may show a problem with our development cycle setup. In my
previous company, different closed-sourced software, we had so called code
freeze. For example it could be 1-2 weeks before actual release and ideally
some users would have time to test the "release-candidate" of QGIS before
going public.
>From wikipedia:
- A *(complete) code freeze*, in which no changes whatsoever are
permitted to a portion or the entirety of the program's source code.
Particularly in large software systems, any change to the source code may
have unintended consequences
<https://en.wikipedia.org/wiki/Regression_bug>, potentially introducing
new bugs; thus, a code freeze helps ensure that a portion of the program
that is known to work correctly will continue to do so. Code freezes are
often employed in the final stages of development, when a particular
release or iteration is being tested, but may also be used to prevent
changes to one portion of a program while another is undergoing development.
Cheers,
Peter
On Wed, Oct 31, 2018 at 6:32 AM Mathieu Pellerin <nirvn.asia at gmail.com>
wrote:
> That's rather unfortunate, but most probably needed. The issue raised,
> 20262, affects WMS(T), XYZ, WFS, etc. layers.
> On top of - and very much due to - the gravity of the bug itself, 3.4 is
> flagged as LTR, and it'd be most appropriate to insure that people jumping
> onto this new LTR aren't left with a bad first impression.
> Math
> On Wed, Oct 31, 2018 at 8:55 AM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> Bah... feels like every major release someone ends up sending an email
>> like this... but in this case, https://issues.qgis.org/issues/20262
>> has totally destroyed QGIS network based providers with Qt 5.11 and
>> above.
>> This is not anyone's fault -- it's an upstream change in the Qt
>> library which changed some behavior we relied on. Not there fault, not
>> our fault. But end result is that it makes QGIS basically unusable for
>> any non gdal/ogr layers on Qt >= 5.11. And unfortunately our major
>> platforms only saw an upgrade to Qt 5.11 late in the bug fixing
>> period, which made this one slow to be identified.
>> https://github.com/qgis/QGIS/pull/8383 should fix it.
>> Soo.... could we break the normal cycle and get a point release out
>> quickly? (Ideally with a couple of days prenotice so that anyone else
>> working on urgent bug fixes could get them in too)
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181031/0099a5be/attachment.html>
