[QGIS-Developer] Python ResourceWarning: unclosed file in Processing Plugin
Nyall Dawson
nyall.dawson at gmail.com
Mon Sep 3 16:03:36 PDT 2018
On Tue, 4 Sep 2018 at 02:56, Martin Isenburg <martin.isenburg at gmail.com> wrote:
> Hello,
> as soon as I run any of my LAStools plugin scripts I get the WARNING "ResourceWarning" about an "unclosed file" shown below in the Python warning window. I use the call "output = subprocess.Popen(....)" to get the stderr output from the process so I can push it to the console once the subprocess is complete with the feedback.pushConsoleInfo(output.decode("utf-8")). Is it bad? Can I fix it? Should I ignore it?
> Complete code:
> https://github.com/rapidlasso/LAStoolsPluginQGIS3/blob/master/LAStools/LAStoolsUtils.py
> Regards.
> Martin
> 2018-09-03T18:34:08 WARNING warning:C:/Users/isenburg/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools\LAStoolsUtils.py:60: ResourceWarning:
> unclosed file
> traceback: File "C:/Users/isenburg/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools\LAStoolsPipelines\flightlinesToDTMandSpikeFreeDSM.py", line 82, in processAlgorithm
> LAStoolsUtils.runLAStools(commands, feedback)
> File "C:/Users/isenburg/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools\LAStoolsUtils.py", line 60, in runLAStools
> output = subprocess.Popen(commandline, shell=True, stdout=subprocess.PIPE, stdin=open(os.devnull), stderr=subprocess.STDOUT, universal_newlines=False).communicate()[0]
I think you need a:
output.wait()
after this line. See
https://stackoverflow.com/questions/23279941/closing-stdin-in-subprocess-popen
Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
