[QGIS-Developer] MAC QGIS 3.x build
David Marteau
dmarteau at 3liz.com
Tue Sep 4 02:19:00 PDT 2018
Hi Peter,
Warning, if you are using macport: qt5.11 is installed by default and you may (or may not) experience some display problems, instead you may choose to stick to qt5.9 by installing
the 'qt59' port
David
> Le 4 sept. 2018 à 11:14, Denis Rouzaud <denis.rouzaud at gmail.com> a écrit :
> Hi Peter,
> You can look at current Homebrew formula:
> https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb <https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb>
> You'll find a very good doc from Larry (althugh might be a bit outdated)
> https://github.com/qgis/homebrew-qgisdev/tree/master/development <https://github.com/qgis/homebrew-qgisdev/tree/master/development>
> Otherwise, there is blog post from David on how to build using Mac ports
> https://www.3liz.com/blog/rldhont/index.php?post/2017/06/01/How-to-build-qgis-on-OSX-with-MacPort <https://www.3liz.com/blog/rldhont/index.php?post/2017/06/01/How-to-build-qgis-on-OSX-with-MacPort>
> If while using one or the other, you feel like updating the readme, do not hesitate to do so ;)
> Cheers,
> Denis
> Le mar. 4 sept. 2018 à 11:04, Peter Petrik <peter.petrik at lutraconsulting.co.uk <mailto:peter.petrik at lutraconsulting.co.uk>> a écrit :
> Hi,
> As a (happy) Linux user, I switched to Mac (High Sierra 10.13.6) for some QGIS development and I see that https://github.com/qgis/QGIS/blob/master/INSTALL <https://github.com/qgis/QGIS/blob/master/INSTALL> still suggests qt4 and python 2.6 for Mac. Does anyone has a suggestion what to use/read to facilitate the building of current master and get quickly up-to-speed?
> Also, can you please point me to the scripts/repositories that are used for official Mac releases?
> I have found https://github.com/OSGeo/homebrew-osgeo4mac <https://github.com/OSGeo/homebrew-osgeo4mac>, but I am not sure if that can be used for development?
> Thanks a lot for any ideas!
> Peter
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>--
> Denis Rouzaud
> denis at opengis.ch <mailto:denis at opengis.ch>
> +41 76 370 21 22 <>
> <>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180904/b9aa7416/attachment.html>
