[QGIS-Developer] Disable scratch layer warning on closing project
Chris Crook ccrook at linz.govt.nz
Fri Sep 7 23:15:01 PDT 2018
Hi
Is there a setting anywhere to disable the warning when closing a project with temporary layers (This layer contains one or more temporary scratch layers.  These layers are not saved to disk ....)
Thanks
Chris
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the QGIS-Developer mailing list
