[QGIS-Developer] QGIS 3 does not allow to embed layers from qgz project files
magerlin
MAP at ramboll.dk
Tue Sep 11 08:55:47 PDT 2018
In Qgis 3 "Embed Layers and Groups" only allows to embed from qgs files, not
qgz:
<http://osgeo-org.1560.x6.nabble.com/file/t202356/Screenshot_2018-09-11_17.png>
I can write *.qgz myself in the filename field and the qgz files appear but
Qgis crashes when I try to use one of them:
Crash ID: 4bbda773b0ca13ca0a43c40842995c035e0b436b
Stack Trace
QgsLayerTreeModel::index2node :
QgsLayerTreeViewIndicator::QgsLayerTreeViewIndicator :
QAbstractItemView::viewportEvent :
QCoreApplicationPrivate::sendThroughObjectEventFilters :
QApplicationPrivate::notify_helper :
QApplication::notify :
QgsApplication::notify :
QCoreApplication::notifyInternal2 :
QApplication::event :
QEventDispatcherWin32Private::sendTimerEvent :
QEventDispatcherWin32::processEvents :
TranslateMessageEx :
TranslateMessage :
qt_plugin_query_metadata :
QEventLoop::exec :
QDialog::exec :
QgisApp::embedLayers :
QMetaObject::activate :
QAction::activate :
QMenu::actionGeometry :
QMenu::mouseReleaseEvent :
QWidget::event :
QMenu::event :
QApplicationPrivate::sendMouseEvent :
QSizePolicy::QSizePolicy :
QGuiApplicationPrivate::processMouseEvent :
QWindowSystemInterface::sendWindowSystemEvents :
TranslateMessage :
QEventLoop::exec :
QCoreApplication::exec :
main :
BaseThreadInitThunk :
RtlUserThreadStart :
QGIS Info
QGIS Version: 3.2.2-Bonn
QGIS code revision: 26842169e9
Compiled against Qt: 5.9.2
Running against Qt: 5.9.2
Compiled against GDAL: 2.2.4
Running against GDAL: 2.2.4
System Info
CPU Type: x86_64
Kernel Type: winnt
Kernel Version: 6.1.7601
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.2.2 in parrallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
