[QGIS-Developer] Build failure on macOS
Tim Sutton
tim at kartoza.com
Sun Sep 16 13:40:09 PDT 2018
Hi all
Building on master 195539d7d3a594da3da6c6874773d8d3d4877551 I get this:
[4/3576 27.2/sec] Generating qgsexpression_texts.cpp
FAILED: src/core/qgsexpression_texts.cpp
cd /Users/timlinux/dev/cpp/QGIS && /usr/local/opt/python3/bin/python3.6 /Users/timlinux/dev/cpp/QGIS/scripts/process_function_template.py /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/src/core/qgsexpression_texts.cpp.temp && /usr/local/Cellar/cmake/3.9.3_1/bin/cmake -DSRC=/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/src/core/qgsexpression_texts.cpp.temp -DDST=/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/src/core/qgsexpression_texts.cpp -P /Users/timlinux/dev/cpp/QGIS/cmake/CopyIfChanged.cmake
resources/function_help/json/to_dm
File "/Users/timlinux/dev/cpp/QGIS/scripts/process_function_template.py", line 47, in <module>
json_params = json.load(function_file)
File "/usr/local/Cellar/python3/3.6.2/Frameworks/Python.framework/Versions/3.6/lib/python3.6/json/__init__.py", line 296, in load
return loads(fp.read(),
File "/usr/local/Cellar/python3/3.6.2/Frameworks/Python.framework/Versions/3.6/lib/python3.6/encodings/ascii.py", line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 580: ordinal not in range(128)
[5/3576 24.4/sec] Running utility command for zzz-processing-stageinstall
[6/3576 11.1/sec] Running utility command for pyqtcompat
ninja: build stopped: subcommand failed.
22:38:16: The process "/usr/local/bin/cmake" exited with code 1.
Error while building/deploying project qgis (kit: QT5 - QGIS Build Kit)
The kit QT5 - QGIS Build Kit has configuration issues which might be the root cause for this problem.
When executing step "Make"
22:38:16: Elapsed time: 00:01.
Does anyone else have this issue?
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180916/9c0178a3/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180916/9c0178a3/attachment-0001.jpg>
Desc: Message signed with OpenPGP
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180916/9c0178a3/attachment-0001.sig>
