[QGIS-Developer] Has QgsLayout.itemById() changed?
Nyall Dawson nyall.dawson at gmail.com
Sun Sep 23 15:06:23 PDT 2018
On Sun, 23 Sep 2018 at 21:50, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> Thank you Nyall and Allesandro.
> So I don't need to file the bus anymore. But who could/would dive into
> this and fix it? And how much would it cost? I might be able to find
> some funding.
Let me kick off some discussions with PyQt upstream, just to confirm
that this is an upstream bug and if so, what would be involved in a
fix.
Nyall
> For now I will use the workaround.
> Raymond
> On 23-09-18 11:48, Nyall Dawson wrote:
> > On Sun, 23 Sep 2018 at 19:37, Alessandro Pasotti <apasotti at gmail.com> wrote:
> >> Do you have any clue about why this issue is not always reproducible?
> > I suspect it's something to do with whether the item was created in
> > Python or c++.
> > Nyall
> >> On Sun, Sep 23, 2018, 11:27 Nyall Dawson <nyall.dawson at gmail.com> wrote:
> >>> On Fri, 21 Sep 2018 at 23:20, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> >>>> which doesn't work anymore, because there is no setText() function on a
> >>>> QgsLayoutItem. Has anything changed recently? Does any one know a solution?
> >>> Nothing has changed recently -- this has always been fragile, and the
> >>> bug lies deep within the library used to create the Python bindings.
> >>> See e.g.
> >>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-QgsLayout-itemById-returns-wrong-object-td5350947.html
> >>> for a workaround
> >>> Nyall
> >>> Nyall
> >>>> Regards,
> >>>> Raymond
> >>>> _______________________________________________
> >>>> QGIS-Developer mailing list
> >>>> QGIS-Developer at lists.osgeo.org
> >>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
More information about the QGIS-Developer mailing list
