[QGIS-Developer] open atlas layout, using python
Nyall Dawson
nyall.dawson at gmail.com
Tue Sep 25 14:57:17 PDT 2018
On Tue, 25 Sep 2018 at 22:36, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> 1. Can I open a layout window with a python command?
designer = iface.openLayoutDesigner( layout )
> 2. Can I turn on "atlas preview" with a python command?
You'd have to do some fragile code to do this. Basically:
- get designer window from designer.view()'s parent window
- find the mActionAtlasPreview child action in the window
- manually toggle it on
This should work, but isn't stable API - so is likely to break ;)
A better approach is to (quickly, before 3.4 final!) file a PR
exposing the toggle atlas preview behavior to
QgsLayoutDesignerInterface. Then you'll be able to just do:
designer.toggleAtlasPreview( True )
Nyall
Hope anyone knows!
> Kind regards,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
