[QGIS-Developer] Updating a layer's datasource in python
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Sep 25 17:13:11 PDT 2018
Hi Olivier,
I have been playing with this and I think you should use the source on the
layer and not on the data provider.
Here is some code (which also modifies the style of the layer)
https://github.com/QGEP/customizer/blob/master/customizer.py#L129-L141
I was doing a layer.reload() after changing the source.
Hope that helps,
Denis
Le mar. 25 sept. 2018 à 19:02, Olivier Dalang <olivier.dalang at gmail.com> a
écrit :
> Dear List,
> As simple as it sounds, I'm struggling with changing the datasource of
> layers with python :
> layer1 = QgsVectorLayer('/path/to/a.shp')
> QgsProject.instance().addMapLayer(layer1)
> layer1.dataProvider().setDataSourceUri('/path/to/b.shp')
> The layer successfully changes on map redraw. However layer1.source()
> stays to the initial layer, so that the change does not persist across
> saves (save and reload, and you get a.shp again).
> The exact same code with a geopackage doesn't work at all (no changes on
> map redraw).
> layer1 = QgsVectorLayer('/path/to/db.gpkg|layer=a')
> layer1.dataProvider().setDataSourceUri ('/path/to/db.gpkg|layer=b')
> There is also an entry in the pyqgis cookbook (here
> <https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/loadlayer.html#id1>,
> scroll down) for QgsVectorLayer. The layer1.source() is correctly updated,
> but again, it works with shapefiles, but not geopackages. And this is for
> vectors only.
> layer1.setDataSource('/path/to/b.shp', "b", "ogr")
> Am I hitting a bug ? Or did I get confused somewhere ?
> As I feel this is a fairly common need, I'd be very grateful if someone
> could help me figure out the recommended way to achieve this, for both
> vectors or rasters. I'll update the pyqgis cookbook in return :-)
> Note that there are workarounds (like replacing with a new layer and
> copying styles over or writing directly to the .qgs file, but they are not
> straightforward and have limitations).
> Thanks !!
> Olivier
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180925/7f739e76/attachment.html>
