[QGIS-Developer] form font barely readable
Matthias Kuhn matthias at opengis.ch
Fri Sep 28 01:49:52 PDT 2018
Hi Richard
On 9/28/18 10:17 AM, Richard Duivenvoorde wrote:
> On 09/28/2018 12:07 AM, Nyall Dawson wrote:
>> On Fri, 28 Sep 2018 at 00:08, Richard Duivenvoorde <rdmailings at duif.net> wrote:
>>> Using the I-tool and viewing via 'Auto open form', the attributes of a
>>> feature are barely readable (see attached screenshot).
>> Oh this has bugged me a LOT too! I'd very much like to see this
>> changed, but I'm not sure if there's some rationale behind it I'm
>> missing...
>> Nyall
> Looking into this a little, we use make the widget 'enabled=false' I think?
> What about instead only do 'readOnly=true'?
> Then you 'miss' the visual cue that a form field is read only.
> There could be a message when you try to edit the field?
> Or in combination with 'frame=false' you would get a form in which the
> fields do not like 'input fields'.
That sounds like an idea.
Have a look here, that's the default behavior with setEnabled, where the
actual modification of the widget is done:
https://github.com/qgis/QGIS/blob/master/src/gui/editorwidgets/core/qgseditorwidgetwrapper.cpp#L65
it needs to be checked with all different widgets if they are still in a
sane and expected readonly state. If one is not, the behavior can be
finetuned in their respective wrapper, as done e.g. here
https://github.com/qgis/QGIS/blob/master/src/gui/editorwidgets/qgsrelationreferencewidgetwrapper.cpp#L136
Cheers
Matthias
> Mmm, was trying to look into this, to find out that we use a wrapper
> around the widgets:
> https://github.com/qgis/QGIS/blob/master/src/gui/qgsattributeform.cpp#L1077
> Removing the
> ww->setEnabled( enabled );
> morphs the input in the default input of QGIS
> ww does not have readonly or frame anymore
> So more difficult then I hoped :-(
> Richard
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180928/44f44856/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180928/44f44856/attachment.png>
More information about the QGIS-Developer mailing list
