[QGIS-Developer] Bug #21460?
Matthias Kuhn matthias at opengis.ch
Tue Apr 9 02:15:47 PDT 2019
Hi
I wonder, what is the best way to answer a question like
> I was wondering when issue x is getting some attention?
Assuming
 - that "issue x" is very important for a user who asks the question
 - that "issue x" is one of 3000 open issues for a developer
The best for the user would obviously be someone replying "Oh sorry, I
missed that one. I'll have a look immediately".
But in reality, unfortunately we all have limited time resources. So
this just would not be true. To me informing people "how to get things
done" is not the nicest answer to get, but it's a very honest one.
With all best intentions
Matthias
/09 April 2019 10:25 Richard Duivenvoorde <rdmailings at duif.net> wrote:/
    On 09/04/2019 03.41, Nyall Dawson wrote:
    > If you can suggest any ways to improve the wording of that post (while
    > keep the core message intact), please let me know.
    >>>> On Mon, Apr 8, 2019 at 4:30 AM Paolo Cavallini wrote:
    >>>>> may I suggest you an interesting read?
    https://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis/
    I want to second Cory, to me it also feels a little rude to tell a
    'user' (not a developer) to try to code or pay for a dev. And I'm a
    dutchie, known for their blunt talk :-)
    @Nyall: in my opinion your followup article:
    http://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis-a-follow-up/
    has a better 'tone' for non developers.
    We should probably mix your followup article with the first one and put
    it in the website (in the 'user' section) so it is translatable, so
    translators can maybe even add more 'cultural politness' to it if
    needed?
    WHO wants to do that (you can earn karma points if you do this !!)??
    We should also make clear that it IS OK to ask for the community to have
    a look at the an issue which makes your(!) live a hell. But also make it
    clear that to be fair your problems are not always the problems of
    somebody else. Same goes for commercial software by the way, only they
    are not as transparent as we are. And that we are humans with not enough
    time to solve all the problems in the world.
    STILL I'm not sure what the right tone is to tell people to read such a
    text though... people (me included!) will feel a little offended anywat
    when not helped but sent to a page to read what they should do...
    I think Geoserver does a good job:
    https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
    And Ian's talk: (though it can maybe be polished a little):
    https://www.ianturton.com/talks/foss4g.html#/how-to-earn-support
    @Cory: please stay on the good side :-)
    May I suggest to make your bug report even better by adding data and
    instructions so for an average developer, it is 10 minutes work to
    replicate your issue? Or should we just create the table and start
    editing? If so please add some steps. For example some googling revealed
    to me that I need: "CREATE EXTENSION IF NOT EXISTS "uuid-ossp";" to use
    the uuid_generate_v4() function you use?
    Also make sure it is actually a QGIS problem, looking into it, it is.
    But it is also a data-schema issue, as you define the problematic
    columns as:
    predecessors uuid[] DEFAULT ARRAY[]::uuid[],
    And the "uuid[]" is not a very common type in the gis world.
    If I'm correct '{""}' (what QGIS now uses for NULL values if the column
    has an array type) is a textual representation of an array with one
    string in it. Would it be better to do '{null}' or even '{}' instead?
    Can you try to create an update query with '{null}' and '{}' values in
    the empty array fields?
    And add these queriies to the bug report?
    Regards,
    QGIS-Developer mailing list
    QGIS-Developer at lists.osgeo.org
    List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
    Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/a3164009/attachment.html>
More information about the QGIS-Developer mailing list
