[QGIS-Developer] QGIS-Server: filter by categories in an OGC compatible way
Andrea Aime andrea.aime at geo-solutions.it
Tue Apr 9 07:47:48 PDT 2019
Hi Andreas,
no, I'm afraid not, the WMS specification provided no way to filter, and
even the SLD/SLD_BODY parameters are not part of the WMS specification,
but part of the SLD one, which a server might decide to implement, or not
Cheers
Andrea
On Tue, Apr 9, 2019 at 4:46 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Andrea,
> Ah - thanks a lot! This helps.
> Is there also a simpler OGC compatible way available to filter away
> categories in a layer if there is no intent to re-style the categories in a
> layer?
> Thanks,
> Andreas
> On 2019-04-09 16:18, Andrea Aime wrote:
> Hi,
> if you want to pass a verbatim SLD, you should use SLD_BODY. This seems to
> work:
> https://services.geo.zg.ch/ows-oereb/Grundwasserschutz?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=2682932,1225299,2684213,1226054&CRS=EPSG:2056&WIDTH=1615&HEIGHT=952&LAYERS=ch.zg.grundwasserschutz.gwszonen&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE&SLD_BODY=%3CStyledLayerDescriptor+xmlns%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22+xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22+xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22+xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld+http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.1.0%2FStyledLayerDescriptor.xsd%22+xmlns%3Ase%3D%22http%3A%2F%2Fwww.opengis.net%2Fse%22+version%3D%221.1.0%22+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A+%3CNamedLayer%3E%0D%0A++%3Cse%3AName%3Ech.zg.grundwasserschutz.gwszonen%3C%2Fse%3AName%3E%0D%0A++%3CUserStyle%3E%0D%0A+++%3Cse%3AName%3Edefault%3C%2Fse%3AName%3E%0D%0A+++%3Cse%3AFeatureTypeStyle%3E%0D%0A++++%3Cse%3ARule%3E%0D%0A+++++%3Cse%3AName%3EGrundwasserschutzzone+S1%3C%2Fse%3AName%3E%0D%0A+++++%3Cse%3ADescription%3E%0D%0A++++++%3Cse%3ATitle%3EGrundwasserschutzzone+S1%3C%2Fse%3ATitle%3E%0D%0A+++++%3C%2Fse%3ADescription%3E%0D%0A+++++%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A++++++%3Cogc%3APropertyIsEqualTo%3E%0D%0A+++++++%3Cogc%3APropertyName%3Etyp_code%3C%2Fogc%3APropertyName%3E%0D%0A+++++++%3Cogc%3ALiteral%3ES1%3C%2Fogc%3ALiteral%3E%0D%0A++++++%3C%2Fogc%3APropertyIsEqualTo%3E%0D%0A+++++%3C%2Fogc%3AFilter%3E%0D%0A+++++%3Cse%3APolygonSymbolizer%3E%0D%0A++++++%3Cse%3AFill%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22fill%22%3E%23003bb3%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AFill%3E%0D%0A++++++%3Cse%3AStroke%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke%22%3E%23000080%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-width%22%3E1%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-linejoin%22%3Ebevel%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AStroke%3E%0D%0A+++++%3C%2Fse%3APolygonSymbolizer%3E%0D%0A++++%3C%2Fse%3ARule%3E%0D%0A+++%3C%2Fse%3AFeatureTypeStyle%3E%0D%0A++%3C%2FUserStyle%3E%0D%0A+%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E
> Using &sld=... you should feed it with a URL that the SLD can be
> downloaded from instead
> (none of this is QGIS specific, it's just how the SLD specification says
> user provided styles should be used).
> Cheers
> Andrea
> On Tue, Apr 9, 2019 at 4:15 PM Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> I did some test:
>> Here is a long URL with the SLD (originally sent by QGIS server, stripped
>> away some RULES manually) and sending it back in a GetMap request:
>> https://services.geo.zg.ch/ows-oereb/Grundwasserschutz?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=2682932,1225299,2684213,1226054&CRS=EPSG:2056&WIDTH=1615&HEIGHT=952&LAYERS=ch.zg.grundwasserschutz.gwszonen&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE&SLD=%3CStyledLayerDescriptor+xmlns%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22+xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22+xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22+xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld+http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.1.0%2FStyledLayerDescriptor.xsd%22+xmlns%3Ase%3D%22http%3A%2F%2Fwww.opengis.net%2Fse%22+version%3D%221.1.0%22+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A+%3CNamedLayer%3E%0D%0A++%3Cse%3AName%3Ech.zg.grundwasserschutz.gwszonen%3C%2Fse%3AName%3E%0D%0A++%3CUserStyle%3E%0D%0A+++%3Cse%3AName%3Edefault%3C%2Fse%3AName%3E%0D%0A+++%3Cse%3AFeatureTypeStyle%3E%0D%0A++++%3Cse%3ARule%3E%0D%0A+++++%3Cse%3AName%3EGrundwasserschutzzone+S1%3C%2Fse%3AName%3E%0D%0A+++++%3Cse%3ADescription%3E%0D%0A++++++%3Cse%3ATitle%3EGrundwasserschutzzone+S1%3C%2Fse%3ATitle%3E%0D%0A+++++%3C%2Fse%3ADescription%3E%0D%0A+++++%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A++++++%3Cogc%3APropertyIsEqualTo%3E%0D%0A+++++++%3Cogc%3APropertyName%3Etyp_code%3C%2Fogc%3APropertyName%3E%0D%0A+++++++%3Cogc%3ALiteral%3ES1%3C%2Fogc%3ALiteral%3E%0D%0A++++++%3C%2Fogc%3APropertyIsEqualTo%3E%0D%0A+++++%3C%2Fogc%3AFilter%3E%0D%0A+++++%3Cse%3APolygonSymbolizer%3E%0D%0A++++++%3Cse%3AFill%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22fill%22%3E%23003bb3%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AFill%3E%0D%0A++++++%3Cse%3AStroke%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke%22%3E%23000080%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-width%22%3E1%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-linejoin%22%3Ebevel%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AStroke%3E%0D%0A+++++%3C%2Fse%3APolygonSymbolizer%3E%0D%0A++++%3C%2Fse%3ARule%3E%0D%0A+++%3C%2Fse%3AFeatureTypeStyle%3E%0D%0A++%3C%2FUserStyle%3E%0D%0A+%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E
>> The response is:
>> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" version="1.3.0
>> <ServiceException code="Invalid Parameter">
>> SLD ('<StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>> xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="
>> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
>> http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd"
>> xmlns:se="http://www.opengis.net/se" version="1.1.0" xmlns:ogc="
>> http://www.opengis.net/ogc"> <NamedLayer>
>> <se:Name>ch.zg.grundwasserschutz.gwszonen</se:Name> <UserStyle>
>> <se:Name>default</se:Name> <se:FeatureTypeStyle> <se:Rule>
>> <se:Name>Grundwasserschutzzone S1</se:Name> <se:Description>
>> <se:Title>Grundwasserschutzzone S1</se:Title> </se:Description> <ogc:Filter
>> xmlns:ogc="http://www.opengis.net/ogc"> <ogc:PropertyIsEqualTo>
>> <ogc:PropertyName>typ_code</ogc:PropertyName> <ogc:Literal>S1</ogc:Literal>
>> </ogc:PropertyIsEqualTo> </ogc:Filter> <se:PolygonSymbolizer> <se:Fill>
>> <se:SvgParameter name="fill">#003bb3</se:SvgParameter> </se:Fill>
>> <se:Stroke> <se:SvgParameter name="stroke">#000080</se:SvgParameter>
>> <se:SvgParameter name="stroke-width">1</se:SvgParameter> <se:SvgParameter
>> name="stroke-linejoin">bevel</se:SvgParameter> </se:Stroke>
>> </se:PolygonSymbolizer> </se:Rule> </se:FeatureTypeStyle> </UserStyle>
>> </NamedLayer> </StyledLayerDescriptor>') cannot be converted into QString
>> </ServiceException>
>> </ServiceExceptionReport>
>> So apparently the SLD cannot be converted to a QString. Is my encoding in
>> the URL above wrong or am I missing a required additional parameter?
>> Can you point me to an example how to create a valid GetMap request with
>> an SLD submitted?
>> Thanks a lot,
>> Andreas
>> On 2019-04-09 15:38, Andreas Neumann wrote:
>> Hi,
>> Does QGIS-Server support SLD styles to filter away RULEs in a GetMap
>> Request?
>> I would assume, yes, but in what encoding would I submit such an SLD in a
>> GET request? I know that one should rather use POST reqests for such long
>> parameters, but for experimenting, it would be ok to use GET.
>> The idea would be to allow users to enable/disable categories within a
>> given layer.
>> The WMS client would first request the available rules with a GetStyles
>> command (that part works fine) and would then filter the RULE (strip away
>> the unwanted RULEs) and resubmit the GetMap with an SLD. Does that work
>> with QGIS server?
>> I know that one can also use the FILTER parameter, but we want to do it
>> in an OGC compatible way, since the client being developed should work with
>> any OGC compatible WMS server.
>> Thanks for your reply,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Regards, Andrea Aime == GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime
> @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054
> Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339
> 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati "GDPR"), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> "GDPR" - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
“GDPR” - copying, dissemination or use of this e-mail or the information
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/136f6f50/attachment-0001.html>
More information about the QGIS-Developer mailing list
