[QGIS-Developer] Bug #21460?
Andrea Aime
andrea.aime at geo-solutions.it
Tue Apr 9 11:00:04 PDT 2019
On Tue, Apr 9, 2019 at 7:00 PM Jonathan Moules <jonathan-lists at lightpear.com>
wrote:
> Hi Andrea,
> As always, I agree with you, but one thing:
> > After all, the GPL license is really clear on the matter: "THE ENTIRE
> RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD
> THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY
> SERVICING, REPAIR OR CORRECTION" Throwing one's frustration at the
> developers that shared code under the above conditions, while somehow
> understandable, really does not make sense and helps nobody.
> To be fair you get the exact same conditions if you throw six digit sums
> to the proprietary vendors too.
Yes indeed, completely agree.
I kind of see an unfortunate tendency to repetition in users, a sort of
"continuity" if you like:
- "I pay for proprietary software, hence I'll pay for support and
fixing" (and agree that getting a fix is really hard, towards "mission
impossible" levels, with large vendors)
- "I did not pay for open source software, hence I won't pay for support
or bug fixing (let alone use my super-precious personal time to help the
community in other ways)". And this is where I get mad :-D
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/ef181597/attachment.html>
