[QGIS-Developer] Inconsistency in QgsServerRequest parameter handling ?
David Marteau
dmarteau at 3liz.com
Wed Apr 10 13:37:18 PDT 2019
To add some precision:
Even if I add an 'allowed' parameter by hand:
> request.setParameter('FI_POINT_TOLERANCE','25')
then
> request.parameter('FI_POINT_TOLERANCE')
return an empty string
> Le 10 avr. 2019 à 19:46, David Marteau <dmarteau at 3liz.com> a écrit :
> Hi devs,
> I found a strange and seemingly inconsistent behavior when accessing QgsServerRequest parameters:
> If you try:
> request.setParameter('FOOBAR','foobar')
> then
> request.parameter('FOOBAR')
> then you get an empty string,
> If you call
> request.parameters()
> Then your get a dictionary with all the values previously set.
> At first glance it seems that request.setParameter enforce use of a limited set of keys (SERVICE…..
> This does not seem very consistent with the fact parameter() should return any value previously set with setParameter and also the fact that
> request.parameters() return all previously defined parameters key/values .
> Furthemore this may be problematic with plugins that define services in python and thus may define any other set of allowed parameters.
> Should I open an issue ?
> David
