[QGIS-Developer] Request for sponsored fix issue #21839
Tom Vanzieleghem
tom.vanzieleghem at gmail.com
Wed Apr 17 08:46:24 PDT 2019
Hi Alessandro,
I’ve indeed tried that option and it partially solves the issue but only when loading db layers while opening an existing project. It does not have any effect when adding a new db layer.
Best Regards,
Tom
> Op 17 apr. 2019 om 15:43 heeft Alessandro Pasotti <apasotti at gmail.com> het volgende geschreven:
> Hi Tom,
> Did you try to uncheck project property "Trust project when data source has no metadata" ?
>> On Wed, Apr 17, 2019 at 3:32 PM Tom Vanzieleghem <tom.vanzieleghem at gmail.com> wrote:
>> Hi,
>> I'm looking for a core developer willing to fix issue #21839, related to the primary key unicty check on PostgreSQL views in QGis 3, in return for a financial contribution.
>> It would suffice if it would already be possible to specify the checkPrimaryKeyUnicity parameter in the datasource uri of a QLR or QGS project file. For the moment this parameter is ignored/overriden for a PostgreSQL dataprovider. No need for GUI changes.
>> As we would like to stick to the 3.4 LTR version backporting would also be appreciated.
>> best regards,
>> Tom Vanzieleghem
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190417/3b052d3d/attachment-0001.html>
