[QGIS-Developer] Which Docker do you use?
David Marteau
dmarteau at 3liz.com
Thu Apr 18 07:31:15 PDT 2019
We (at 3liz) publish a qgis docker platform to be used as base image for running qgis server or other qgis based application:
The docker file is on github: https://github.com/3liz/docker-qgis-platform <https://github.com/3liz/docker-qgis-platform> and you can pull images from dockerhub: https://hub.docker.com/r/3liz/qgis-platform <https://hub.docker.com/r/3liz/qgis-platform>
We have images from release (buster), nigtly-release (buster), ltr (stretch), nightly-ltr (stretch)
You will find a full-featured/ready-to-run qgis-server here: https://hub.docker.com/r/3liz/qgis-map-server <https://hub.docker.com/r/3liz/qgis-map-server> (Dockerfile at: https://github.com/3liz/docker-qgis-server <https://github.com/3liz/docker-qgis-server>)
These images are based on the qgis.org <http://qgis.org/> debian packages and not from a custom build.
If you plan to run qgis server, you may need to start a frame-buffered X server with Xvfb, if not, fonts are not found by Qt and no labels are rendered.
See here for an example a starting an Xvfb server before running a qgis server: https://github.com/3liz/docker-qgis-server/blob/master/docker-entrypoint.sh#L33
David,
> Le 18 avr. 2019 à 15:52, Luca Manganelli <luca.manganelli at comune.trento.it> a écrit :
> Hi,
> I'm testing the Dockerhub's camptocamp qgis-server running on docker, but it seems that it has some problems (i.e. not rendering labels).
> Furthermore, it seems strange that I cannot find any repository about this Dockerfile.
> I see that there another, like openquake.
> Which one do you use? I'm trying to use the one that supports QGIS 3 LTR (at moment 3.4.6).
> Thank you in advance :-)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190418/ec595433/attachment.html>
