[QGIS-Developer] Bug in QgsPathResolver ?
David Marteau dmarteau at 3liz.com
Fri Apr 19 06:23:43 PDT 2019
Hi devs,
I have  a strange behavior with QgsPathResolver that prevent layer to be loaded if a QgsProject read config file from relative path:
The problem has been reduced to the following behavior (pyQgis):
# Init a QgsPathResolver as with a relative path
pr = QgsPathResolver('./geography/data/france_parts.qgs')
pr.readPath('./france_parts/france_parts.shp')
# Output -> '/geography/data/france_parts/france_parts.shp'
# Note the leading '/'
Worst:
pr = QgsPathResolver('../geography/data/france_parts.qgs')
# Output -> '/../geography/data/france_parts/france_parts.shp'
# which is a meaningless path
The side effect is that if you do:
prj = QgsProject()
prj.read("./geography/data/france_parts.qgs")
then you get the error:
Qgis OGR: Cannot open /geography/data/france_parts/france_parts.shp.()
Qgis : 1 unavailable layers found:
Qgis :  * ./france_parts/france_parts.shp
This is with Qgis 3.6.1
Can anybody confirm that this behavior is a bug ? I will submit a PR  if this is the case.
Thanks,
Cheers
David
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190419/90148850/attachment-0001.html>
More information about the QGIS-Developer mailing list
