[QGIS-Developer] Proposal: changing the behaviour of QgsFeatureRequest
Matthias Kuhn
matthias at opengis.ch
Tue Apr 30 05:28:40 PDT 2019
Sorry, I lost you here.
I think for both proposals three QgsFeatureRequests will need to be
created, requested and iterators generated.
Can you paste a minimal code sample here that demonstrates the use of
your proposed API?
Thanks Matthias
On 4/30/19 1:00 PM, Alexis R.L. wrote:
> Hi,
> Well I could rework iterators to use the provided Fids as the base
> list to iterate over, this would mean that instead of checking every
> feature for each evaluation ( from what I'm seeing each evaluation
> goes through every feature and check for either the id number or if
> the expression is true.)
> If we are doing 3 evaluation on 3 distinct symbols, this mean that
> every feature will be iterated over 3 times. Because each features are
> checked one by one for each of the 3 expression to evaluate.
> By using Fids as the base list and incrementing the index of it, each
> feature should be evaluated only once and no Fids check would be
> necessary. (Assuming a simple legend with a depth of one.)
> This would drasticly speed up things when many loops are required on a
> single feature.
> Alexis Roy-Lizotte
> Le mar. 30 avr. 2019 à 06:30, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> a écrit :
> Hi,
> An expression `attribute = 'major_road' AND $id IN (1,2,3)` should
> have the same result on the number of features in the iterator. Or
> I am missing something.
> Matthias
> On 4/30/19 12:13 PM, Alexis R.L. wrote:
>> Greetings Mr.Kuhn,
>> Well in my case the fact that each symbol node is evaluated add
>> some lenght to the computation, if I can make something that
>> would only iterate over a given list of Fids, (and at the same
>> time prevent having to iterate over each feature to check if that
>> feature is within the given list of feature) we would move from
>> something that takes x by n loops to something that would only
>> take around x loop ( where x is the number of features and n is
>> the number of symbol).
>> For other use case the gain might be minimal. Other similar
>> behaviour could be used with selected features (though I'm not
>> sure if this is a perfect match for this also.)
>> This gain in efficiency is why I want to alter the iterator
>> itself rather than fiddling with expressions, despite the fact
>> that this is also a possibility but far less optimal for the
>> reason mentioned above.
>> I just want to know what would be the best way to alter the
>> iteration process without breaking and in a way that could be
>> leveraged.
>> Thanks.
>> Alexis Roy-Lizotte
>> Le mar. 30 avr. 2019 à 02:31, Matthias Kuhn <matthias at opengis.ch
>> Hi,
>> I like the idea of a nicer API to combine several filter
>> conditions. Currently the only possibility to perform this
>> operation is to write a filter expression as a string or by
>> combining expression nodes.
>> I am not convinced however that this should be done directly
>> on QgsFilterRequest level. It feels a bit like reimplementing
>> the expression engine on another level again.
>> Some questions that come to my mind:
>> * Are these filters always combined with AND or also OR?
>> * Can these filters eventually be nested?
>> * How should we deal with compiling expressions, should that
>> be implemented again?
>> An alternative approach would be to work on a nicer API for
>> an expression builder to require 1) less string manipulation
>> when building an expression and 2) have more introspection
>> capabilities when manipulating an expression.
>> Regards
>> Matthias
>> On 4/29/19 9:02 PM, Alexis R.L. wrote:
>>> Greetings Mr. Dawson,
>>> Thanks for the reply,
>>> The tests that I did with the method in my PR was provider
>>> agnostic but still entailed looping over every feature to do
>>> the check. Could you provide idea or methods that could
>>> enable this behaviour in an API friendly way?
>>> Should I make a new iterator entirely or should I modify
>>> existing methods and add a trigger like I tested in my PR?
>>> Thanks!
>>> Alexis Roy-Lizotte
>>> Le dim. 28 avr. 2019 à 19:46, Nyall Dawson
>>> <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> a
>>> écrit :
>>> On Sun, 28 Apr 2019 at 07:18, Alexis R.L.
>>> <alroyliz0 at gmail.com <mailto:alroyliz0 at gmail.com>> wrote:
>>> > Greetings Everyone,
>>> > While working on my PR (9648) I noticed that
>>> expression filter and a list of feature IDs are both
>>> considered the same thing cannot be used as two
>>> filtering criteria.
>>> > I am aware that the intent was to only have one
>>> element active to filter out features other than the
>>> rectangle(? might be wrong on that one).
>>> > What I am wondering if it would be a good thing to
>>> have both co exist (mostly for my PR as of now). A
>>> simply way to do so would be to use the give feature ids
>>> as the list to iterate over and check for the expression
>>> if there is one.
>>> I also think this would be desirable. The tricky part
>>> (well, one
>>> tricky part -- feature iterators are low level stuff,
>>> lots of
>>> complexity there!) is avoiding any API breakage while
>>> adding new
>>> methods to handle your use case.
>>> The other (SUPER) tricky bit is that any change to
>>> feature requests
>>> usually requires accompanying changes to every vector
>>> data provider in
>>> order to keep consistent behaviour across all these
>>> providers. The
>>> same request should always give the same result,
>>> regardless of the
>>> actual underlying data provider. The consequence of this
>>> is that
>>> you'll need to be update the postgres, mssql, oracle,
>>> OGR, memory,
>>> spatialite, wfs, arcgis feature server, db2, and vector
>>> layer feature
>>> iterator code. You'll also need to add many new unit
>>> tests to cover
>>> all the changes to the different providers.
>>> Definitely not a trivial change! Don't let this put you
>>> off making it,
>>> but just be aware that this change would take even a
>>> QGIS core
>>> developer a week or more of work to implement.
>>> Nyall
>>> > I assume that such a thing might be implemented
>>> without touching the current behaviour, otherwise one
>>> would have to remove either the expression or the IDs in
>>> some case when we want to override the current filtering
>>> method.
>>> > Using multiple filtering method might be better than
>>> only forcing one and would provide more flexibility.
>>> > As I have a PR that is related to this
>>> (https://github.com/qgis/QGIS/pull/9816 ) I would like
>>> to address this point in it and would like to have the
>>> discussion occur there as to the best way to implement
>>> such a thing without any breakage if people are not
>>> opposed to having only one filtering method in
>>> qgsfeaturerequest.
>>> > Thanks and have a nice day!
>>> > Alex
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> <mailto:QGIS-Developer at lists.osgeo.org>
>>> > List info:
>>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe:
>>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Matthias Kuhn
>> matthias at opengis.ch <mailto:matthias at opengis.ch>
>> +41 (0)76 435 67 63 <tel:+41764356763>
>> OPENGIS.ch Logo <http://www.opengis.ch>
> Matthias Kuhn
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190430/7eb8bb48/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190430/7eb8bb48/attachment-0001.png>
