[QGIS-Developer] [qgis/QGIS] Allow setting a custom path pre-processor for QgsPathResolver (#30842)
Nyall Dawson
nyall.dawson at gmail.com
Wed Aug 21 16:10:08 PDT 2019
On Tue, 20 Aug 2019 at 16:49, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> Hi Nyall,
> That sounds exactly what we need!
> In this case I would think addPathPreprocessor() would be a better name
> than setPathPreprocessor().
> The chain order should not matter since every preprocessor will check
> for something specific, in our case paths with our plugin name.
See https://github.com/qgis/QGIS/pull/31331 - feedback welcome!
Nyall
> Kind regards,
> Raymond
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
> On 20-08-19 08:33, Nyall Dawson wrote:
> > On Fri, 16 Aug 2019 at 22:24, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
> >> Hi Nyall and others here,
> >> I'm writing here to the dev list because the PR has already been pulled
> >> and closed.
> >> We implemented this new code in our plugin and it works very well! One
> >> thing is bothering me though, and I hope I am wrong here.
> >> As I wanted to do a clean up in the plugin unload method, I figured I
> >> can never remove the preprocessor. Since our plugin overwrites the
> >> pathPreprocessor, it also overwrites any existing preprocessor. Or even
> >> worse, another plugin could overwrite ours! :)
> >> I think the most elegant solution is a list of pathPreprocessors that
> >> will return either the input path or an edited one (like now). The path
> >> resolver would run them all in a chain and fix all paths for all
> >> plugins. By giving them an ID, it would also be possible to remove them
> >> (or overwrite them with a processor that always returns the input) on
> >> unloading the plugin.
> > Right. I debated this a lot internally when writing that API hook, and
> > came to the conclusion that it's not really intended for use in public
> > plugins, but rather just for those "internal only" organisation
> > plugins. I guess this was the wrong choice :P
> > I'd propose we could adjust the api:
> > static void setPathPreprocessor( const std::function< QString(
> > const QString &filename )> &processor );
> > to
> > static QString setPathPreprocessor( const std::function< QString(
> > which returns an automatically generated unique string identifying the
> > processor.
> > And then we add new call
> > static void removePathPreprocessor( const QString& id );
> > Internally, the processors would just be called in the order they've
> > been set, chaining the result from one into the next.
> > How's that sound?
> > Nyall
> >> I guess this is quite some work for a not much used feature (yet) and
> >> maybe the reason you chose to implement it this less comlplicated way.
> >> But it is potentially really hard to debug problems if 2 or more plugins
> >> collide on this and we want to reproduce the error. We would need to
> >> know all the plugins and versions our users have installed and look into
> >> that code.
> >> Am I right? Please let me know your thoughts about this.
> >> Kind regards,
> >> Raymond
> >> On 25-07-19 00:41, Nyall Dawson wrote:
> >>> Merged #30842 <https://github.com/qgis/QGIS/pull/30842> into master.
> >>> You are receiving this because you commented.
> >>> Reply to this email directly, view it on GitHub
> >>> <https://github.com/qgis/QGIS/pull/30842?email_source=notifications&email_token=AAFGO63EK64SG3XXAUAIAVTQBDLC3A5CNFSM4IFT6T2KYY3PNVWWK3TUL52HS4DFWZEXG43VMVCXMZLOORHG65DJMZUWGYLUNFXW5KTDN5WW2ZLOORPWSZGOSV5I2GQ#event-2507836698>,
> >>> or mute the thread
> >>> <https://github.com/notifications/unsubscribe-auth/AAFGO63PMWSOTDPTH365GSLQBDLC3ANCNFSM4IFT6T2A>.
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
