[QGIS-Developer] List of dependencies versions used in official released
Jürgen E. Fischer jef at norbit.de
Fri Aug 23 01:58:48 PDT 2019
Hi Alex,
On Fri, 23. Aug 2019 at 08:57:42 +0100, Alexandre Neto wrote:
> Is there a place where I can check what dependency versions are being used
> in our Linux, Windows and Mac official releases?
I don't think so.  You would need to check the actual packages and the current
state of the underlying distributions - eg. not all dependencies in the
debian/ubuntu packages will be versioned.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190823/844e1db3/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190823/844e1db3/attachment.ksh>
More information about the QGIS-Developer mailing list
