[QGIS-Developer] Problems in running OTB
Áron Gergely
aron.gergely at rasterra.nl
Wed Dec 4 05:42:20 PST 2019
Hi Paolo and list,
I am using the Segmentation algorithm on Linux without major problems.
(OTB 6.6 and now 7.0 with QGIS 3.10). But indeed it does not work out
of the box:
Even when raster output does not not apply to the Segmentation alg , a
"bogus" value would have to be entered in the output box to avoid an
exception and get the alg running.
Also, the OTB processing provider settings interface has some issues:
when I try to change configuration values (namely the amount of max RAM
), I get an error " argument has unexpected type 'int' "
Best regards,
Aron
On 04/12/2019 13:23, Pedro Venâncio wrote:
> Hi Paolo,
> I'm using OTB (6.6.1 and 7.0.0) with QGIS 3.10.0, without any problem,
> but I'm on Windows.
> About the issues you reported (".raster.out.tif" and vectors not being
> loaded), I think this thread can explain almost all of them (I had the
> same doubts some time ago):
> https://gitlab.orfeo-toolbox.org/orfeotoolbox/qgis-otb-plugin/issues/30
> Best regards,
> Pedro Venâncio
> Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it>>
> escreveu no dia terça, 3/12/2019 à(s) 12:00:
> Moreover, the vector resulting vector layer is not automatically
> loaded.
> Cheers.
> Il 03/12/19 12:44, Paolo Cavallini ha scritto:
> > Hi all,
> > OTB algs apparently do not work on QGIS 3.10 out of the box:
> > * if a raster output is not explicitly selected I get an error:
> > “.raster.out.tif” files are not supported as outputs for this
> algorithm
> > * if a vector output is not explicitly selected (with
> filename.ext) I
> > get another error:
> > 2019-12-03 12:30:43 (FATAL) Segmentation: itk::ERROR: No OGR driver
> > known to OTB to create and handle a DataSource named
> </tmp/processing_1845b856b9b44fa79bd7d1f2f834ffa0/processing_5bc31a5446744fff806de1d05d4b0240/4083978a97c840adbe135f8409847bfd/mode.vector.out.file>.
> > If confirmed I can open two tickets.
> > Additionally (but this must be done by OTB itself, nothing to do
> with QGIS):
> > ERROR 1: TopologyException: Input geom 1 is invalid: Ring
> > Self-intersection at or near point 1651438.0098749998
> 4818821.1863940004
> > at 1651438.0098749998 4818821.1863940004
> > Cheers.
> Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
> QGIS.ORG <http://QGIS.ORG> Chair:
> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Email Signature Kind Regards,
Áron Gergely
+31 (0) 6 38 70 97 66
*Rasterra* | www.rasterra.nl <https://www.rasterra.nl>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191204/64f77ff7/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191204/64f77ff7/attachment.vcf>
