[QGIS-Developer] Improve build times with ccache
Matthias Kuhn
matthias at opengis.ch
Mon Dec 16 00:22:08 PST 2019
Hi again,
Just remembered another nifty trick. Only compile the target
qgis_desktop (ninja qgis_desktop) when working on desktop related code.
That will also skip compiling server and linking tests. Therefore: if
you want to run cpp tests locally, you have to also to remember to build
them individually.
And by the way welcome on board :)
Matthias
On 12/16/19 9:02 AM, Matthias Kuhn wrote:
> Hi,
> Ccache is certainly a good idea.
> The other one is to actually keep several source and build folders in
> parallel (e.g. release-3_4, release-3_10, master). I would recommend
> getting familiar with "git worktree" which is an amazing utility to
> use several sources in parallel, based on the same git configuration.
> I quite often develop small fixes on a master tree with mixed patches
> on top and then compile this mixed branch and do:
> git commit
> git worktree add ../my_new_functionality
> cd ../my_new_functionality
> git rebase -i qgis/master
> # only keep the commits to be pushed
> git push -u my_own_repo my_new_functionality
> For small fixes here and there this is super fast to work with
> Hope this helps
> Matthias
> On 12/16/19 8:57 AM, Samweli wrote:
>> Hi, I just joined Kartoza and I am going to be doing a bunch of work
>> on the
>> QGIS core. Can someone share a good practice to avoid lengthy
>> recompilation
>> times when I switch branches. I'm using ccache in compiling.
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
