[QGIS-Developer] proj6 to be and QGIS...
Richard Duivenvoorde
rdmailings at duif.net
Fri Feb 1 11:29:02 PST 2019
Hi Devs,
Seeing this tweet:
https://twitter.com/EvenRouault/status/1091067967763288066
pointing to
https://erouault.blogspot.com/2019/01/srs-barn-raising-8th-report-ready-for.html
With the help of Even I've been able to compile proj+gdal master (to
become proj6). If you want to compile and use it next to the proj/gdal
from your distro (Debian testing here) you maybe need some extra tips,
which Even jotted down here:
https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev
So now "we" can start to make this work with QGIS.... :-)
[354/4155] Building CXX object
src/core/CMakeF...is_core.dir/qgscoordinatereferencesystem.cpp.o
FAILED:
src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o
ccache /usr/bin/c++ -DQT_CONCURRENT_LIB -DQT_CORE_LIB
-DQT_DISABLE_DEPRECATED_BEFORE=0 -DQT_GUI_LIB -DQT_NETWORK_LIB
-DQT_NO_CAST_TO_ASCII -DQT_POSITIONING_LIB -DQT_PRINTSUPPORT_LIB
-DQT_SERIALPORT_LIB -DQT_SQL_LIB -DQT_SVG_LIB -DQT_WEBKITWIDGETS_LIB
-DQT_WEBKIT_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB
-DTEST_DATA_DIR=\"/home/richard/git/qgisgdal/tests/testdata\"
-DWITH_BINDINGS -DWITH_QTWEBKIT -D_HAVE_PTHREAD_ -Dqgis_core_EXPORTS -I.
-I../src/core -Isrc/core -I../src/core/3d -I../src/core/annotations
-I../src/core/auth -I../src/core/dxf -I../src/core/effects
-I../src/core/expression -I../src/core/fieldformatter
-I../src/core/geometry -I../src/core/geocms -I../src/core/geocms/geonode
-I../src/core/layertree -I../src/core/layout -I../src/core/locator
-I../src/core/metadata -I../src/core/pal -I../src/core/processing
-I../src/core/processing/models -I../src/core/providers
-I../src/core/providers/memory -I../src/core/raster
-I../src/core/renderer -I../src/core/scalebar -I../src/core/symbology
-I../src/core/mesh -I../src/core/validity -I../external/kdbush/include
-I../external/nmea -I../external/poly2tri -isystem
/home/richard/bin/proj/include -isystem /home/richard/bin/gdal/include
-isystem /usr/include/QtCrypto -isystem /usr/include/qt5keychain
-isystem /usr/include/x86_64-linux-gnu/qt5 -isystem
/usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem
/usr/include/x86_64-linux-gnu/qt5/QtCore -isystem
/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem
/usr/include/x86_64-linux-gnu/qt5/QtXml -isystem
/usr/include/x86_64-linux-gnu/qt5/QtGui -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem
/usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem
/usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem
/usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWebKitWidgets -isystem
/usr/include/x86_64-linux-gnu/qt5/QtWebKit -isystem
/usr/include/x86_64-linux-gnu/qt5/QtSql -isystem
/usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem
/usr/include/x86_64-linux-gnu/qt5/QtPositioning -Wall -Wextra
-Wno-long-long -Wformat-security -Wno-strict-aliasing -g -fPIC
-fvisibility=hidden -fPIC -std=gnu++11 -MD -MT
src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o -MF
src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o.d
-o src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o
-c ../src/core/qgscoordinatereferencesystem.cpp
../src/core/qgscoordinatereferencesystem.cpp: In member function ‘bool
QgsCoordinateReferenceSystem::createFromWkt(const QString&)’:
../src/core/qgscoordinatereferencesystem.cpp:642:5: error: ‘OSRFixup’
was not declared in this scope
OSRFixup( d->mCRS );
../src/core/qgscoordinatereferencesystem.cpp:642:5: note: suggested
alternative: ‘OGRField’
OGRField
../src/core/qgscoordinatereferencesystem.cpp: In member function ‘void
QgsCoordinateReferenceSystem::setMapUnits()’:
../src/core/qgscoordinatereferencesystem.cpp:1181:3: error: ‘OSRFixup’
../src/core/qgscoordinatereferencesystem.cpp:1181:3: note: suggested
OGRField
[363/4155] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsdataitem.cpp.o
