[QGIS-Developer] Jupyter Console Plugin for QGIS?
Luigi Pirelli
luipir at gmail.com
Sun Feb 3 02:00:12 PST 2019
There were already a past GSoC focused on something similar... But oriented
to use qgis as back end for mapping only.
IMHO a GSoC should be on remove (if possible) at console ernel sharing
limitation when embedded.. Not specifically a qgis oriented stuff.
I hadn't time to investigate, but 1.5y ago I challenged various talented
devs and none found a solution... But having a well focused GSoC probably
could help :)
On Sunday, 3 February 2019, Stefan Keller <sfkeller at gmail.com> wrote:
> A Jupyter Console QGIS Plugin would probably be a good "Google Summer
> of Code 2019 Idea"?
> https://github.com/qgis/QGIS/wiki/Google-Summer-of-Code-2019-Ideas
> :Stefan
> Am Do., 31. Jan. 2019 um 23:07 Uhr schrieb Luigi Pirelli <luipir at gmail.com
> > I already wrote many times about QT Console limitations to interact with
> external kernels... I dind't know about RichJupyterWidget and I'm not
> updated about qt console evlution.
> > IMHO if it works would be great... since 1.5y ago it was not possible.
> > Luigi Pirelli
> > * LinkedIn: https://www.linkedin.com/in/luigipirelli
> > * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> > * GitHub: https://github.com/luipir
> > * Mastering QGIS 2nd Edition:
> > * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> > * Hire me: http://goo.gl/BYRQKg
> > On Thu, 31 Jan 2019 at 21:03, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> >> Stefan,
> >> this is actually a very good idea, I've started something similar a few
> years ago, but its scope was limited to embedding the IPython console
> inside QGIS, the plugin is available here: https://plugins.qgis.org/
> plugins/IPyConsole/
> >> It is based on QtConsole.
> >> Perhaps it could be a starting point, IIRC Luigi also explored this
> possibility while we were working together in Boundless.
> >> On Thu, Jan 31, 2019 at 8:11 PM Stefan Keller <sfkeller at gmail.com>
> wrote:
> >>> Hi,
> >>> August 2017 Tim S. blogged about "Plotting the future of QGIS" [1] and
> >>> mentioned as no. 1. "We need to beef up the analytical capabilities in
> >>> QGIS". There he asked "why not provide both a Jupyter Notebook"
> >>> embedded into QGIS and pointed to options to integrate the Jupyter Qt
> >>> console [2]. QGIS/Jupyter integration has been mentioned 2017 as
> >>> possible GSoC but then can't see other activities.
> >>> So what is your opinion about writing a QGIS Python Plugin which
> >>> allows to run Python notebooks an accesses the QGIS processing power
> >>> (e.g. using Qt's RichJupyterWidget).
> >>> Any developments or thoughts on this?
> >>> :Stefan
> >>> [1] https://blog.qgis.org/2017/08/25/plotting-the-future-of-qgis/
> >>> [2] https://qtconsole.readthedocs.io/en/stable/#embedding-the-
> qtconsole-in-a-qt-application
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Alessandro Pasotti
> >> w3: www.itopen.it
Luigi Pirelli
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190203/7c9b5094/attachment-0001.html>
