[QGIS-Developer] Jupyter Console Plugin for QGIS?
Luigi Pirelli
luipir at gmail.com
Mon Feb 4 01:16:38 PST 2019
I would thing it carefully, mainly to avoid to involve someone to works on
something that we are not sure it could work! and I can investigate only
after the UserConf (hopefully)
If there is a implementation possibility? I would be happy to mentor.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Sun, 3 Feb 2019 at 12:20, Stefan Keller <sfkeller at gmail.com> wrote:
> Am So., 3. Feb. 2019 um 11:00 Uhr schrieb Luigi Pirelli <luipir at gmail.com
> > I hadn't time to investigate, but 1.5y ago I challenged various talented
> devs and none found a solution...
> > But having a well focused GSoC probably could help :)
> So ;-) , do we have a good idea for GSoC 2019 - and a mentor (you)?
> My contribution could be use and test cases...
> :Stefan
> > There were already a past GSoC focused on something similar... But
> oriented to use qgis as back end for mapping only.
> > IMHO a GSoC should be on remove (if possible) at console ernel sharing
> limitation when embedded.. Not specifically a qgis oriented stuff.
> devs and none found a solution... But having a well focused GSoC probably
> could help :)
> > On Sunday, 3 February 2019, Stefan Keller <sfkeller at gmail.com> wrote:
> >> A Jupyter Console QGIS Plugin would probably be a good "Google Summer
> >> of Code 2019 Idea"?
> >> https://github.com/qgis/QGIS/wiki/Google-Summer-of-Code-2019-Ideas
> >> :Stefan
> >> Am Do., 31. Jan. 2019 um 23:07 Uhr schrieb Luigi Pirelli <
> luipir at gmail.com>:
> >> > I already wrote many times about QT Console limitations to interact
> with external kernels... I dind't know about RichJupyterWidget and I'm not
> updated about qt console evlution.
> >> > IMHO if it works would be great... since 1.5y ago it was not possible.
> >> > Luigi Pirelli
> >> > * Stackexchange:
> >> > On Thu, 31 Jan 2019 at 21:03, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> >> >> Stefan,
> >> >> this is actually a very good idea, I've started something similar a
> few years ago, but its scope was limited to embedding the IPython console
> inside QGIS, the plugin is available here:
> https://plugins.qgis.org/plugins/IPyConsole/
> >> >> It is based on QtConsole.
> >> >> Perhaps it could be a starting point, IIRC Luigi also explored this
> possibility while we were working together in Boundless.
> >> >> On Thu, Jan 31, 2019 at 8:11 PM Stefan Keller <sfkeller at gmail.com>
> wrote:
> >> >>> Hi,
> >> >>> August 2017 Tim S. blogged about "Plotting the future of QGIS" [1]
> and
> >> >>> mentioned as no. 1. "We need to beef up the analytical capabilities
> in
> >> >>> QGIS". There he asked "why not provide both a Jupyter Notebook"
> >> >>> embedded into QGIS and pointed to options to integrate the Jupyter
> Qt
> >> >>> console [2]. QGIS/Jupyter integration has been mentioned 2017 as
> >> >>> possible GSoC but then can't see other activities.
> >> >>> So what is your opinion about writing a QGIS Python Plugin which
> >> >>> allows to run Python notebooks an accesses the QGIS processing power
> >> >>> (e.g. using Qt's RichJupyterWidget).
> >> >>> Any developments or thoughts on this?
> >> >>> :Stefan
> >> >>> [1] https://blog.qgis.org/2017/08/25/plotting-the-future-of-qgis/
> >> >>> [2]
> https://qtconsole.readthedocs.io/en/stable/#embedding-the-qtconsole-in-a-qt-application
> >> >>> _______________________________________________
> >> >>> QGIS-Developer mailing list
> >> >>> QGIS-Developer at lists.osgeo.org
> >> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> >>> Unsubscribe:
> >> >> Alessandro Pasotti
> >> >> w3: www.itopen.it
> >> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Luigi Pirelli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190204/2af4118e/attachment-0001.html>
