[QGIS-Developer] Tackling Postgis layers connection recover
Paolo Cavallini
cavallini at faunalia.it
Mon Feb 4 23:00:31 PST 2019
Agreed, a long standing annoying issue. Thanks for taking it.
Cheers.
Il 4 febbraio 2019 23:32:39 CET, Nyall Dawson <nyall.dawson at gmail.com> ha scritto:
>On Tue, 5 Feb 2019 at 05:54, Timothé Perez
><timothe at pragma-innovation.fr> wrote:
>> Hello qgis-devs,
>> This is my first message here and first contribution to QGIS, so I
>thank you in advance for being indulgent and do not hesitate to correct
>me on any mistake I will make.
>> I didn't want to jump right into proposing my patch "as is" in a PR
>as I'm new to this project, so first I wanted to discuss about it to
>make sure I got it right.
>> Here's a recap of what I have found so far (sorry if it's a bit
>long):
>> I'm using QGIS 3.4 with a PostgreSQL database to store layers and I'm
>facing the same issue as described in
>https://issues.qgis.org/issues/20170 : unrecoverable PostgreSQL
>connections.
>> I have cloned the repo and started to dig, as it is really annoying
>because it forces you to abandon your changes and close and reopen your
>project.
>Upfront, thanks for the great attitude. This is one of the MOST
>effective ways to get bugs fixed... rolling up your sleeves and fixing
>them yourself!
>> To reproduce the problem, the simplest way is to spin a local
>PostgreSQL database with postgis and create a table with just a serial
>and a geometry:
>> CREATE TABLE foo (id serial primary key, geometry GEOMETRY(POINT,
>4326));
>> Open it in QGIS, create several features, save them then simply
>restart the PostgreSQL service so that all connections are forced to be
>closed.
>> QGIS logs will display that the connections to PostgreSQL were lost
>but recovered and features will still be accessible.
>> However if I start editing the layer by adding a feature and then
>call save, it will fail:
>> 2019-02-04T19:11:30 CRITICAL Layer foo : PostGIS error while
>adding features: FATAL: terminating connection due to administrator
>command
>> la connexion au serveur a été coupée de façon inattendue
>> Le serveur s'est peut-être arrêté anormalement avant ou
>durant le
>> traitement de la requête.
>> 2019-02-04T19:11:30 WARNING Commit errors : Could not commit
>changes to layer foo
>> 2019-02-04T19:11:34 CRITICAL Layer foo : PostGIS error while
>adding features: no result buffer
>> 2019-02-04T19:11:34 WARNING Commit errors : Could not commit
>> My only option is to cancel my edits and reload the project to regain
>full access to the db.
>> So in fact this problem has 2 causes: (time to dig in the C++ code)
>*snip*
>> I am willing to propose a PR if my fixes make sense and are
>acceptable, this will fix an annoying issue.
>They both sound reasonable to me, and yes, valuables fixes for an
>annoying issues! Looking forward to the PRs! (One request: please file
>these as two separate PRs, so both fixes can be discussed and reviewed
>independently.)
>Nyall
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190205/ec4f57f9/attachment-0001.html>
