[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Luigi Pirelli luipir at gmail.com
Wed Feb 6 03:39:20 PST 2019
Sorry if I¡m too superficial without knowing deeply the plugin use cases,
this is my 2c:
if VESPER kiging is the reason limitate the plugin to only windows, is
something I do not understand. QGIS/processing with RSpatial, saga and
grass are full of kiging interpolation methods why not use the available
multiplatforms tools?
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Wed, 6 Feb 2019 at 07:29, <Christina.Ratcliff at csiro.au> wrote:
> Hi QGIS dev list,
> I have just uploaded a new QGIS 2.18.x plugin called PAT - Precision
> Agriculture Tools.  It relies on VESPER,  a Windows only bit of software so
> therefore I went ahead writing a Windows only plugin using QGIS 2.18.x and
> the non-QGIS Python dependencies of rasterio, Fiona, geopandas and our
> pyprecag package.
> The majority of our users are Windows users and are the likes of Farmers
> and Ag consultants with no programming experience and very little QGIS
> experience which also led to the decision of making PAT a Windows only
> plugin. I have developed a series of dependency checks based on the Windows
> environment and create a Windows batchfile that the user can launch to
> install the Python dependencies correctly for use with QGIS.
> On uploading to the QGIS repository I have been advised by @pcav (see
> https://github.com/CSIRO-Precision-Agriculture/PAT_QGIS_Plugin/issues/7 )
> that PAT must support Linux and OSX operating environments. I have had a
> look on https://plugins.qgis.org/ and I cannot find where this is listed
> in bullet points under *how to add your plugin to this repository* as a
> requirement for the approval of plugins. @pcav advised that I email this
> list regarding this issue.
> Is it acceptable to add a line in the metadata.txt file clearly pointing
> out that this plugin is to be used in Windows only and will it still be
> approved for the QGIS plugin repository?
> If not what are my options?
> Are there any guides on how to best setup and test QGIS plugins for Linux
> and OSX environments? I only have access to Windows at the moment and I am
> a novice at Python programming in these other environments.
> Any help or direction would be greatly appreciated.
> Kind Regards,
> Christina Ratcliff
> PLEASE NOTE
> The information contained in this email may be confidential or privileged.
> Any unauthorised use or disclosure is prohibited. If you have received this
> email in error, please delete it immediately and notify the sender by
> return email. Thank you. To the extent permitted by law, CSIRO does not
> represent, warrant and/or guarantee that the integrity of this
> communication has been maintained or that the communication is free of
> errors, virus, interception or interference.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190206/ad84ebd3/attachment-0001.html>
More information about the QGIS-Developer mailing list
