[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Axel Andersson
axel.n.c.andersson at gmail.com
Wed Feb 6 04:59:08 PST 2019
On the subject, is there any possibility to test a plugin at another
platform?
I'm developing my plugin on Windows machine and I have a Linux server,
which I can test the plugin on but when it comes to OSX I have no machine
to test it on. Does anyone have experience/good cookbooks how to set up a
OSX virtual box or something similar to test a plugin in?
Best regards
Axel
On Wed, 6 Feb 2019 at 13:05, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi
> On 2/6/19 12:47 PM, Nathan Woodrow wrote:
> > QGIS is for the users in the end, if this opens a new world of users,
> > and note this is government funded, I don't think we should avoid
> > allowing these kinds of things in. This isn't a core feature of QGIS
> > and more of an exception than a rule. I don't see most plugins going
> > this route but the few that do because of X reasons they have no
> > control over should still be part of the community I think.
> > I really don't see the harm here as it's not something that most
> > people will know or care about in the end. Getting plugins to work
> > cross-platform is a lot of work and I don't really like pushing people
> > away because they can't do it for whatever reason. If this was going
> > to be a core feature I would be on your side for it but the plugins
> > are for the users.
> > I would also note we have some features of QGIS that only work on some
> > platforms and not others and we are fine with that because it makes it
> > better for those users, so this is the same here IMO. Pushing them
> > out to a self-hosted plugin repo just adds extra overhead and limits
> > user base and visibility of well-funded work that we should embrace.
> I am tempted to think in the same direction. Most plugins will be
> cross-platform anyway because Python and because Qt and because QGIS.
> If they are not and it's trivial to solve (e.g. someone is using \ as
> path separator instead of os.path.join...) than things can go through an
> issue report. If it's more complex it's a question of effort vs.
> benefit. If it's a single-purpose use-case specific plugin which is
> intended to be run inside a specific organization / scenario, then I
> don't see the benefit of investing a lot of effort into something that
> will never be used.
> IMO we should be open to anyone and in parallel encourage people to
> support as many platforms as possible. E.g. adding metadata with
> supported platforms might help to be more transparent about supported
> platform, filter plugins in the plugin manager and offer specific help
> to make plugins cross-platform down the road.
> Bests
> Matthias
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190206/c7d6e8c8/attachment-0001.html>
