[QGIS-Developer] Changes to @atlas_feature?
Nyall Dawson
nyall.dawson at gmail.com
Mon Feb 11 20:47:40 PST 2019
On Tue, 12 Feb 2019 at 09:59, Spencer Gardner <spencergardner at gmail.com> wrote:
> I have a map document set up with a report that filters an attribute table based on an attribute in the layers used for filtering (i.e. the "atlas" layer for lack of a better Reports-oriented term). In 3.4.2 I could use the @atlas_feature variable to grab the attribute I needed, but I've discovered this doesn't work in 3.4.4. Was there a change to the handling of @atlas_feature between the two versions? If so, I'll file a bug report. Otherwise, I'm at a loss as to what's going on.
That's an unfortunate bug in 3.4.4 - it's fixed for next weeks 3.4.5 release.
Nyall
> Thanks!
> Spencer
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
