[QGIS-Developer] Adding Layer tree embedded widgets programmatically
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Feb 13 07:28:25 PST 2019
Sorry, forgot to add the link :blush:
https://gis.stackexchange.com/questions/232367/showing-transparency-slider-by-default-in-layers-panel-of-qgis
On 13-02-19 12:59, Raymond Nijssen wrote:
> Hi Richard,
> Here is some example code. I will try to make it work now.
> Groetjes!
> Raymond
> On 13-02-19 12:37, Richard Duivenvoorde wrote:
>> Hi Devs,
>> Thinking about creating a small plugin which would add a 'Layer tree
>> embedded widget' to a layer in the legend, I hit:
>> https://github.com/qgis/QGIS/pull/3170
>> with a nice example on how to create such a widget (with 2 minor tweaks
>> see below).
>> But my question is if it is possible (in the python plugin) to attach
>> such widget to a specific layer? Now it is working but you can only
>> activate it via the layerproperties dialog.
>> I could not find a example or hint for it.
>> Any pointers appreciated.
>> Regards,
>> PS
>> To make Martins example https://github.com/qgis/QGIS/pull/3170) work in
>> QGIS3:
>> from PyQt4.QtGui import QComboBox
>> becomes
>> from qgis.PyQt.QtWidgets import QComboBox
>> QgsLayerTreeEmbeddedWidgetRegistry.instance().addProvider(provider)
>> becomes
>> QgsGui.layerTreeEmbeddedWidgetRegistry().addProvider(provider)
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
