[QGIS-Developer] Download the QGIS User Manual HTML Files
Alexandre Neto
senhor.neto at gmail.com
Tue Feb 19 08:49:40 PST 2019
Hi Matthias,
If I recall, each language is a separate build, therefore, adding a zipping
step in the makefile would create individual packages for each one of them.
Let me confirm if the languages output share the screenshots or not. If
that is the case, then it might be easier (even smaller) to zip the full
content of what we have in the site.
Alexandre Neto
A ter, 19/02/2019, 08:33, Matthias Kuhn <matthias at opengis.ch> escreveu:
> Hi Alexandre,
> What would be required to add an additional build step to zip the whole
> content including everything after build and push that to a downloadable
> location?
> Matthias
> On 18.02.19 18:55, Alexandre Neto wrote:
> Hi,
> Yes, once the documentation is built, all images are gathered in the same
> folder, which means that there is no way split each document in a clean
> way. To separate a certain document (e. g., the user manual) you need to
> ignore the other sections in the conf.py or directly on the sphinx_build
> command.
> On the other hand, adding other languages shouldn't increase the file size
> that much, because most images are shared (we don't have many localized
> screenshots).
> See you soon.
> Alexandre Neto
> A seg, 18/02/2019, 16:51, Matthias Kuhn <matthias at opengis.ch> escreveu:
>> Hi Richard
>> On 2/18/19 5:10 PM, Richard Duivenvoorde wrote:
>> On 18/02/2019 16.24, Matthias Kuhn wrote:
>> Hi,
>> In the QGIS options, there is a list of alternative help paths to search
>> for documentation.
>> Is there a zip file (or other means) available to download these docs to
>> keep them locally? I failed to find something.
>> Hi Matthias,
>> Nope, nothing available. The idea is/was that we add an extra step in
>> the build Makefile to just zip the language build and rsync it to the
>> docs server, OR to another download server.
>> One thing to note is that we (maybe Alexander Neto has better details)
>> do not have separated builds/image directories for all the docs in the
>> documentation tree (Documentation, PythonCookbook, Gentle Gis Intro, Doc
>> Guidelines).
>> I created a zip from this nights build for you:https://docs.qgis.org/testing/qgisdocs_en.zip (183Mb)
>> Thanks a lot for that!
>> I would be happy to split this up though.
>> My idea was to let people choose to download one language (for the
>> non-testing builds).
>> I was hoping that we could leave it zipped on the file-system and be
>> able to view in either in users browser OR in an embedded webkit widget
>> or so.
>> How much data are we talking about, the 183Mb from the link above?
>> If it's not considerably more, I would say in order to minimize the
>> overhead we could just serve this monolithic file with all doc
>> parts/languages included in a first step and require the user to unzip it
>> himself.
>> Regards
>> Matthias
>> Regards,
>> Richard
>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Matthias Kuhn
>> +41 (0)76 435 67 63 <+41764356763>
>> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190219/9b300d3e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190219/9b300d3e/attachment.png>
