[QGIS-Developer] Suggest a Solution
Parameshwaran P R parameshwar.developer at gmail.com
Thu Feb 21 22:17:23 PST 2019
Dear Sir/Madam,
I am trying to rebuild the application using ( https://github.com/qgis/QGIS
) github source code while i am facing a problem like as shown below:
[image: image.png]
I was able to build exe and its running but without taking python, it would
be of great help if you guys help me out. I have set  .env file with
required libs as below:
PATH=C:\OSGEO4~1\apps\qgis\bin;C:\OSGeo4W64\apps\Python37;C:\OSGeo4W64\apps\Python37\Scripts;C:\OSGEO4~1\apps\qt5\bin;C:\OSGEO4~1\apps\Python27\Scripts;C:\OSGEO4~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32\WBem;C:\OSGEO4~1\apps\msys\bin
GDAL_DATA=C:\OSGEO4~1\share\gdal
GDAL_DRIVER_PATH=C:\OSGEO4~1\bin\gdalplugins
GDAL_FILENAME_IS_UTF8=YES
GEOTIFF_CSV=C:\OSGEO4~1\share\epsg_csv
JPEGMEM=1000000
OSGEO4W_ROOT=C:\OSGEO4~1
PROJ_LIB=C:\OSGEO4~1\share\proj
PYTHONHOME=C:\OSGeo4W64\apps\Python37
QGIS_PREFIX_PATH=C:/OSGEO4~1/apps/qgis
QT_PLUGIN_PATH=C:\OSGEO4~1\apps\qgis\qtplugins;C:\OSGEO4~1\apps\qt5\plugins
QT_RASTER_CLIP_LIMIT=4096
VSI_CACHE=TRUE
VSI_CACHE_SIZE=1000000
O4W_QT_PREFIX=C:/OSGEO4~1/apps/Qt5
O4W_QT_BINARIES=C:/OSGEO4~1/apps/Qt5/bin
O4W_QT_PLUGINS=C:/OSGEO4~1/apps/Qt5/plugins
O4W_QT_LIBRARIES=C:/OSGEO4~1/apps/Qt5/lib
O4W_QT_TRANSLATIONS=C:/OSGEO4~1/apps/Qt5/translations
O4W_QT_HEADERS=C:/OSGEO4~1/apps/Qt5/include
This is the error i am getting, please help,
Couldn't load PyQGIS.
Python support will be disabled.
  File "", line 1, in
  File "C:/OSGEO4~1/apps/qgis/./python\qgis\core\__init__.py", line 27, in
    from qgis._core import *
ImportError: DLL load failed: The specified procedure could not be found.
Thank you in Advance
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190222/5b79d1c0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190222/5b79d1c0/attachment-0001.png>
More information about the QGIS-Developer mailing list
