[QGIS-Developer] Python script to count the number of feature for each unique values
kimaidou
kimaidou at gmail.com
Tue Feb 26 00:25:21 PST 2019
Thanks a lot Nyall, setting the NoGeometry flags and subset of fields does
improve the speed by factor 3 for my test layer ( 300k features and 80 (!)
fields )
Regards
Michaël
Le lun. 25 févr. 2019 à 23:48, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Tue, 26 Feb 2019 at 03:31, kimaidou <kimaidou at gmail.com> wrote:
> > Hi all,
> > I needed to gather basic stats for a layer containing multiple fields. I
> created the following gist to compute the number of features per each
> unique value for a list of given fields
> > https://gist.github.com/mdouchin/a234efb7e67ebd8dae3a04cb26cf5e72
> Checkout trap #3 from
> http://nyalldawson.net/2016/10/speeding-up-your-pyqgis-scripts/.
> Specifically, since you aren’t doing anything with the geometry, and
> are only using a single attribute from the layer, by calling setFlags(
> QgsFeatureRequest.NoGeometry ) and setSubsetOfAttributes() you can
> tell QGIS that you don’t need the geometry, and only require a single
> attribute’s value in the feature request. This will give a huge speed
> boost to the feature fetching.
> > I know I could use PostgreSQL to do it (see
> https://twitter.com/kimaidou/status/1100053546978983936 conversation),
> wich is much faster, but I needed a quick way to do it with Python.
> > I tested virtual layers too, but my source layer has many fields (with
> some heavy data) and the copy/pasting into spatialite was not efficient
> here.
> > The method uniqueValues(fieldIndex) of QgsVectorLayer is pretty fast
> compared to my iteration through the layer features. Any hint how to
> improve the speed of my calculation ?
> Potentially this could be a new method in QgsVectorDataProvider which
> sends a native query to be executed on the backend (like uniqueValues
> does -- that's why it's so fast). But that would require an addition
> to the c++ QgsVectorDataProvider class, and implementations in the
> popular vector data providers.
> Nyall
> > Regards,
> > Michaël
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190226/4d340b1f/attachment.html>
