[QGIS-Developer] Pyrcc5 is not installed , pyuic4 is not in the path and other errors trying to build a plugin framework
Ian Turton
ijturton at gmail.com
Thu Feb 28 00:14:06 PST 2019
I was playing with this yesterday, provided you don't care about python2
you can add
call "C:\OSGeo4W64\bin\o4w_env.bat" call "C:\OSGeo4W64\bin\qt5_env.bat"
call "C:\OSGeo4W64\bin\py3_env.bat" #make this apply to your user
set PATH=%PATH%;D:\PhotonUser\AppData\Roaming\Python\Python37\Scripts\
to the osgeo4w.bat file and all works fine
Ian
On Wed, 27 Feb 2019 at 19:47, J L <jeffloun at refractions.net> wrote:
> Hi All,
> I've installed QGis desktop 3.6.0 from the OSGeo4w web installer on my
> windows 10 machine. This most recent time with a default express-install. I
> tried various things before on a different win7 machine and I thought maybe
> a completely fresh install on a newer computer would work better, so this
> was all the first time install on this machine.
> Once I install and run the plugin "Plugin Builder3" , fill out the dialogs
> then press "generate" to get a basic plugin framework made for me, I get
> the error: "The resource compiler pyrcc5 was not found in your path.
> You'll have to manually compile the resources.qrc file with pyrcc5 before
> installing your plugin."
> I saw a stackexchange question that seems to solve this problem,
> https://gis.stackexchange.com/questions/273552/pyrcc5-is-not-recognized-as-an-internal-or-external-command
> Run some bat files to get the right directories added to the path. That
> seems to allow me to build the resource as a one off.
> I believe the next step is to deploy using pb_tool. I don't have that, so I
> installed pb_tool from the OSGeo4w shell with, "pip install pb_tool"
> but then I get errors when running "pb_tool deploy" in my plugin directory,
> "pyuic4 is not in your path---unable to compile your ui files pyrcc4 is
> not in your path---unable to compile your resource file(s)"
> Seems like a path issue again, so I run the bat files from the
> stackexchange answer to add them again in my osgeo4w shell, then I get this:
> C:\MyFiles\Medina\Generated_Plugin_Code\topology_edit>pb_tool deploy File
> "C:\OSGEO4~1\apps\Python37\lib\site.py", line 177 file=sys.stderr)
> which seems very odd to me. I don't think I should try to solve syntax
> errors in teh python scripts. I feel like I must be doing something wrong
> here, or there is a bug in the install that doesn't include these things
> automatically, I assume the idea would be to have all the tools needed
> installed by default.
> I can get the plugin deployed by manually building the resources with the
> stackexchange bat file advice, then manually copy it to the plugin
> directory, but I thought I would report my experience in case there was an
> easy way that allows me to use pb_tool and automate that.
> Cheers,
> -Jeff
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190228/5c7ce854/attachment-0001.html>
