[QGIS-Developer] Label engine only using integer part of size etc.
Nyall Dawson
nyall.dawson at gmail.com
Mon Jan 7 16:09:20 PST 2019
On Mon, 7 Jan 2019 at 21:34, magerlin <MAP at ramboll.dk> wrote:
> It appears to me that in QGIS 3.4.3 (Win7) the label engine only use the
> integer part of sizes at least when it comes to size of buffer and the
> distance for cartographic placement:
> Increasing numbers from 1mm to 1.5 mm makes no difference, first when
> reaching 2.0 mm a difference is seen
Can you elaborate? Are you referring to the rendering of the buffer,
or something else?
Nyall
> Regards Morten
> Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
> Windows 7, 64bit
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
