[QGIS-Developer] QGIS batch files in OSGeo4W are still calling GRASS 7.4.2
Pedro Venâncio
pedrongvenancio at gmail.com
Thu Jan 10 06:35:31 PST 2019
Hi Jurgen,
GRASS Plugin is back again to nightly builds! Checked in QGIS 3.4.3-12 and
2.18.27-4.
Thank you very much!
Best regards,
Pedro
Pedro Venâncio <pedrongvenancio at gmail.com> escreveu no dia quarta,
9/01/2019 à(s) 18:34:
> Hi Jurgen,
> That's correct! I found the problem using GRASS in Processing, and just
> checked if it was fixed in Processing (and in the batch files)!
> I just realized today that GRASS 7 plugin was not there.
> Hope it can be solved easily!
> Best regards,
> Pedro
> Na(o) qua, 9/01/2019, 17:47, Jürgen E. Fischer <jef at norbit.de> escreveu:
>> So that means you just verified that the batch files were updated, but
>> not that
>> it actually changed anything? Or did you just check grass in processing?
>> I at least didn't even look after I saw the above. Sorry. ;)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190110/5c0885bc/attachment.html>
