[QGIS-Developer] LineString vs MultiLineString - QGIS2 vs QGIS 3
matteo
matteo.ghetta at gmail.com
Mon Jan 21 23:44:50 PST 2019
sorry, encrypted....
On 1/22/19 8:43 AM, matteo wrote:
> Hi Matthias,
> thanks for the feedback and inputs. Well the topic is going tricky:
> * create a new line (just line because shapefile is not able to
> understand single/multi) in Q3
> * add a line and some parts to the same line
> * load the shape in Q2
> * the shape is already recognized as Linestring (and not Multilinestring)
> * using the Processing algorithm works fine (lines are "separated"
> well), but the layer remains, of course, Linestring
> The same approach in Q3 works fine. Before the algorithm the shapefile
> is read as Multilinestring and after the algorithm as Linestring
> Does it make sense?
> Cheers and thanks
> Matteo
