[QGIS-Developer] WFS and NULL values
René-Luc Dhont
rldhont at gmail.com
Wed Jan 23 00:31:20 PST 2019
Hi Allessandro,
Do you speak about these PR:
* https://github.com/qgis/QGIS/pull/8536 [Server] Null field value in
GML has to be empty string 2.18
* https://github.com/qgis/QGIS/pull/8537 [Server][WFS] Null field value
in GML has to be empty string 3.4
I don't think it is a GML specific issue, but something about XSD and XML.
Regards,
René-Luc
Le 23/01/2019 à 09:14, Paul Blottiere a écrit :
> Hi Alessandro,
> > If it is a bug I can work on the fix, but maybe I'm missing something.
> Have you taken a look to the compliance OGC tests for WFS 1.X? If
> there's tests about this particular point, we'll know for sure if it's
> something to fix.
> Regards.
> Paul
> Le mar. 22 janv. 2019 à 17:51, Alessandro Pasotti <apasotti at gmail.com
> <mailto:apasotti at gmail.com>> a écrit :
> Hi all,
> while working on QGIS server I noticed that WFS GetFeature returns
> NULL values as empty tags while according to the majority of the
> sources I've found it should not include it in the XML response
> (GML2 at least, I'm not sure about GML3 yet).
> See:
> http://osgeo-org.1560.x6.nabble.com/Why-the-WFS-does-not-return-the-NULL-value-field-td3802398.html
> apparently this is also what geoserver does.
> Any opinion?
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190123/07d93c6c/attachment.html>
