[QGIS-Developer] Error during master compilation
ricardocba
ricardocb1 at gmail.com
Thu Jan 24 12:53:20 PST 2019
Hi devs,
When I try to compile with a new source version of QGIS 3 I receive a error
and checking in previous posts, it's similar to this:
http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Error-during-master-compilation-td5357230.html
But it says that in a previous commit it had beed fixed.
My OS is Linux Mint 18.3 Sylvia
The received error is:
[ 11%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/processing/qgsprocessingutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/processing/qgsprocessingregistry.cpp.o
In file included from
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingregistry.cpp:20:0:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:
In member function ‘virtual QgsProcessingParameterType::ParameterFlags
QgsProcessingParameterTypeVectorDestination::flags() const’:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:603:13:
error: ‘QgsProcessingParameterType::ParameterFlags {aka class
QFlags<QgsProcessingParameterType::ParameterFlag>}’ has no member named
‘setFlag’
flags.setFlag( ParameterFlag::ExposeToModeler, false );
QgsProcessingParameterTypeFileDestination::flags() const’:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:648:13:
‘setFlag’
QgsProcessingParameterTypeFolderDestination::flags() const’:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:693:13:
‘setFlag’
QgsProcessingParameterTypeRasterDestination::flags() const’:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:737:13:
‘setFlag’
QgsProcessingParameterTypeFeatureSink::flags() const’:
/home/ricardo/dev/cpp/QGIS/src/core/processing/qgsprocessingparametertypeimpl.h:1028:13:
‘setFlag’
src/core/CMakeFiles/qgis_core.dir/build.make:3544: recipe for target
'src/core/CMakeFiles/qgis_core.dir/processing/qgsprocessingregistry.cpp.o'
failed
make[2]: ***
[src/core/CMakeFiles/qgis_core.dir/processing/qgsprocessingregistry.cpp.o]
Error 1
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:1243: recipe for target
'src/core/CMakeFiles/qgis_core.dir/all' failed
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
Makefile:160: recipe for target 'all' failed
make: *** [all] Error 2
Some suggestions?
Thank you,
Ricardo
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
