[QGIS-Developer] QGIS and Proj 6
Paolo Cavallini
cavallini at faunalia.it
Mon Jun 3 18:53:02 PDT 2019
Thanks Nyall. You Australians should be proud of this forward thinking (as well as giving birth to Nyall, of course ;) ).
Cheers.
Il 3 giugno 2019 09:28:34 CEST, Nyall Dawson <nyall.dawson at gmail.com> ha scritto:
>Hi all,
>Following the merge of https://github.com/qgis/QGIS/pull/30040 , I now
>consider QGIS' port to the Proj 6 API complete. Here's a bit of a
>summary of what's been done here (on builds based on proj 6.1 and
>later only, more on that later[1])
>- The Proj CRS database is now used to populate QGIS' internal CRS
>database. We no longer use the combination of GDAL CSV files and
>manual QGIS overrides we've used till now. This means that ALL
>responsibility for CRS definitions and updating these sit were they
>belong, upstream in the proj library. It also means we'll be an exact
>match wrt projections as other tools which have completed the port,
>such as GDAL 3.0. (All this goodness is thanks to the GDAL barn
>raising effort). We still HAVE an internal projection database, in
>order not to break existing 3.x API, so we'll need to revisit that at
>4.0 and see if it can be safely removed then.
>- We rely entirely on Proj 6's wonderful logic for generating the best
>coordinate operation to transform between CRS pairs now. This means
>(amongst other stuff), we correctly support complex things like
>operations which require a "pivot datum", e.g. transformation to and
>from GDA2020 coordinate systems. Again, this is thanks to the GDAL
>barn raising effort... if it wasn't for that, we'd be... YEARS away
>from even dreaming about supporting these correctly. Seriously, hats
>off to the proj/GDAL teams here, they've done a brilliant effort, and
>have been tirelessly answering tons of questions on their mailing
>lists.
>- Instead of the older approach QGIS used for datum transformations
>(carrying around our own table of when grid shift files can be used),
>we now use proj to determine these. This considerably changes the user
>interface shown when a user has opted into selecting manually a
>transform to use when multiple transforms exist, and we now show a
>simplified list of available (and non-available) pathways.
>- We also use proj's database to populate lists of available
>ellipsoids for use in distance and area calculations. This has cleaned
>up the ellipsoid choices considerably, and added many additional
>ellipsoid definitions as a result. (woohoo... no more duplicate
>"WGS84"/"WGS 84" entries!)
>- The UX for notifying users about issues in coordinate transforms is
>greatly improved, e.g. users are now alerted when a more accurate
>transform is possible, but not usable on their system (e.g. due to
>missing .gsb grid shift files). Wherever possible, we present users
>with direct download links to obtain these required/desired grid shift
>files. The intention here is to ensure users are informed when
>transforms can be improved, instead of silently falling back to less
>accurate options.
>- Users also now have the option of placing grid shift files in "proj"
>folder off their user profile. This means users can install grid shift
>files and make them available in QGIS without requiring administrative
>rights (possibly in future we could make QGIS fire up a background
>task which automatically downloads and installs grids on demand...)
>- We've also completed a project which began back in the lead-up to
>3.0, which ensures that project-specific transformation pathway
>settings are correctly respected EVERYWHERE a coordinate transform is
>performed. This also means we're ready for the next stage in handling
>4d coordinate transforms (when these start to land in 2020 and beyond)
>As noted above, a lot of this is only possible thanks to improvements
>in the proj and gdal libraries, which landed as a result of the GDAL
>barn raising effort. On the QGIS side, it was ONLY possible thanks to
>funding from the Australian ICSM. It's been a HUGE undertaking, so I'm
>extremely grateful that the ICSM has had the foresight to invest into
>QGIS and open source software development in this way.
>Nyall
>[1] Note that building 3.8 using the Proj 6 library requires a minimum
>of Proj 6.1 -- it's not possible to build using Proj 6.0. There was an
>API call added in 6.1 which we require, and I couldn't work around.
>Sorry for any inconveniences this causes!
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190604/5291a9a2/attachment-0001.html>
