[QGIS-Developer] New version notifications
Stefan Steiger
Steiger at cor-management.ch
Thu Jun 6 01:57:50 PDT 2019
And for that reason, just use docker, and you don't have that problem.
( instead, you might have others ;) )
Works fine for me with MSSQL-Server 2017 & Viber on Ubuntu 19.04, with OpenSSL 1.1.
-----Ursprüngliche Nachricht-----
Von: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Jürgen E. Fischer
Gesendet: Mittwoch, 5. Juni 2019 22:17
An: qgis-developer at lists.osgeo.org
Betreff: Re: [QGIS-Developer] New version notifications
Hi Cory,
On Wed, 05. Jun 2019 at 11:03:26 -0400, Cory Albrecht wrote:
> Except I got the package from QGIS's *own* repo, as I indicated. If
> QGIS is going to be alerting me that there is a new version, shouldn't
> that new version be available in the QGIS repo?
Depends. If you're using a distribution that doesn't have the necessary dependencies for the newer version, the newer version will never reach the repo for that distribution.
But you'll still get the notification about the latest version and in this case it just means that you not only have to upgrade QGIS to get it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
