[QGIS-Developer] QGIS Server 3.4.7 and WFS Filtering PropertyIsLike
René-Luc Dhont
rldhont at gmail.com
Wed Jun 12 01:06:44 PDT 2019
Hi Luca,
The OGC Filter element is required as the document element for filter
parameter.
Regards,
René-Luc
Le 11/06/2019 à 15:59, Luca Manganelli a écrit :
> Addendum.
> I discovered what problem was.
> OWSLib generates an URL like this:
> http:// ....WFSHOST .../&FILTER=<ogc:PropertyIsLike wildCard="%"
> singleChar="_" escapeChar="\"
> matchCase="false"><ogc:PropertyName>nome_via</ogc:PropertyName><ogc:Literal>VIA
> A%</ogc:Literal></ogc:PropertyIsLike>
> but it seems that QGIS Server doesn't like this. We should add
> <ogc:Filter> and </ogc:Filter> at start and the end of the FILTER value:
> http:// ....WFSHOST .../&FILTER=<ogc:Filter><ogc:PropertyIsLike
> wildCard="%" singleChar="_" escapeChar="\"
> A%</ogc:Literal></ogc:PropertyIsLike></ogc:Filter>
> with the last URL, the WFS query works!
> Il giorno mar 11 giu 2019 alle ore 14:18 Luca Manganelli
> <luca.manganelli at comune.trento.it
> <mailto:luca.manganelli at comune.trento.it>> ha scritto:
> Hello,
> I'm trying to make this python 3 code with OwsLib working.
> In particular, I'm searching a road with the name starting by "VIA
> F.", but QGIS Server returns me a road named VIA MATTEOTTI...
> Does QGIS Server support PropertyIsLike in WFS?
> #!/usr/bim/python3
> from owslib.wfs import WebFeatureService
> from owslib.etree import etree
> from owslib.fes import PropertyIsEqualTo, PropertyIsLike, BBox
> wfs =
> WebFeatureService(url='https://cartografia.comunelavis.it/wms/cbase')
> filt = PropertyIsLike(propertyname='nome_via', literal='VIA F.%',
> wildCard='%', matchCase=False)
> filterxml = etree.tostring(filt.toXML()).decode("utf-8")
> feature = wfs.getfeature(typename=['Civici'], maxfeatures=1,
> filter=filterxml)
> gml = etree.parse(feature)
> print(etree.tostring(gml))
> Luca Manganelli
> Assistente informatico
> Servizio Innovazione e Sistemi digitali
> Via Ezio Maccani 148
> 38121 Trento (TN)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190612/d687c95e/attachment.html>
