[QGIS-Developer] CRS troubles (QGIS 3.6.3, Proj 6.1.0) [solved]
Hernán De Angelis dhdeangelis at comhem.se
Fri Jun 14 14:01:29 PDT 2019
Compiled and installed QGIS-master. Works like charm!
H.
On 2019-06-14 19:26, Hernán De Angelis wrote:
> Hi QGIS developers
> I am writing to this list in the hope of finding some clues about the
> following problem. This has also been presented in the user list (*).
> I have built 3.6.3 from source against proj 6.1.0 and GDAL 3.0.0. None
> of which had any problems during build. Even Proj 6.1.0 test suite
> passes perfectly. However, the newly built QGIS has troubles with the
> CRS list in that a lot of the usual systems are either missing or have
> changed names. For example, the usual EPSG:4326 is called IGNF:WGS84G.
> Others are just plainly missing and those in my projects are replaced
> by some "user defined" designation. There are also problems when
> trying to display a WMS service since the CRS available at the service
> seem to go unrecognized. This is regrettable since this turns QGIS
> large unusable for me.
> It might be interesting to note that both QGIS "make" and  "make
> install" complain that
> proj_create: crs not found
> On the other hand, both GDAL and GRASS, that are dependent on Proj do
> not seem to have any problems with Proj 6.1.0.
> I have compiled many times, both 3.6.2. and 3.6.3 and I am having the
> same problem everytime. I wonder if this is happening due to some
> local problem in my installation (fresh openSUSE 15.1 install) or some
> glitch due to recent changes in proj.
> Is this a known issue?
> Any hint will be appreciated!
> Thanks in advance, and thanks for your efforts in developing this
> great tool!
> H.
> (*) problem described in the QGIS user mailing list:
> https://lists.osgeo.org/pipermail/qgis-user/2019-June/043302.html
> https://lists.osgeo.org/pipermail/qgis-user/2019-June/043306.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
