[QGIS-Developer] translate plugin gui and log messages
Jonas
qgis at ag99.de
Wed Jun 19 12:08:42 PDT 2019
You can just use the pylupdate5 script, its in
%OSGeo4Win%\apps\Python37\Scripts
It loads your .pro file and creates the .ts files which you can open in
QtLinguist. After translating you release within QtLinguist to a .qm file.
See:
https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html?highlight=plugin#ts-file
jonas
On 19.06.2019 20:01, C Hamilton wrote:
> I am also interested in how you do this on Windows because I had a
> request to add translation ability to the Shape Tools plugin, but
> these instructions don't seem to include anything for Windows.
> Thanks,
> Calvin
> On Wed, Jun 19, 2019 at 2:24 AM matteo <matteo.ghetta at gmail.com
> <mailto:matteo.ghetta at gmail.com>> wrote:
> Hi Roberta,
> well the process is pretty easy and straightforward.
> I use the Makefile to manage all the process [0].
> Basically the steps are:
> * adding a list to locales in the Makefile, like: LOCALES = en it nl
> * always in the Makefile add all the paths to the files that contains
> the string you want to translate (managed by the self.tr
> <http://self.tr>() method):
> SOURCES = \
> __init__.py \
> plugin.py plugin_dialog.py
> UI_FILES = plugin_base.ui
> * now you can use make transup to create the ts file in all the
> languages
> * translate using the software you prefer
> * compile the ts in qm using make transcompile
> That's it. Whenever you add/change something in the files/UI you
> have to
> run make transup again, translate, recompile
> Cheers
> Matteo
> [0]
> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html#translate-using-makefile
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190619/57d9840f/attachment.html>
