[QGIS-Developer] Preferred way to set startup options on Windows and is qgis_global_settings.ini used or not
Larry Shaffer
larrys at dakotacarto.com
Wed Jun 19 14:58:57 PDT 2019
Hi All,
Of note from the Boundless docs repo is this little script I wrote to dump
existing settings to an .ini file:
https://github.com/boundlessgeo/desktop-documentation/blob/master/docs/source/system_admins/qgis-settings-to-ini.py
Just load it into the Python Console's editor and run. It may need updated
a bit to be purely Python 3, for installs that don't have Python 2 around.
I think it should be added to QGIS src code repo, maybe under 'resources,'
and linked-to from QGIS docs. It is already GPLv2+ licensed.
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Wed, Jun 19, 2019 at 6:17 AM DelazJ <delazj at gmail.com> wrote:
> Hi all,
> Does this not help
> https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html#deploying-qgis-within-an-organization
> Regards,
> Harrissou
> Le mer. 19 juin 2019 à 14:11, Richard Duivenvoorde <rdmailings at duif.net>
> a écrit :
>> On 19/06/2019 11.00, Alexandre Neto wrote:
>> > Hi Richard,
>> > In preparation for a release of Boundless Desktop 2, which would be
>> > based on QGIS 3 (I don't know nothing about it now) we prepared some
>> > documentation for system administrators. See if any of this helps:
>> https://github.com/boundlessgeo/desktop-documentation/tree/master/docs/source/system_admins
>> > BTW, I am not sure if any of this was specific of the product or if it
>> > should work with any version of QGIS.
>> Hi Alexandre,
>> From that docs, I think only the globalsetting.rst is still relevant.
>> And there is already info about it in the docs.
>> But I agree we should have more info for sysadmins, who have to deploy
>> QGIS in large scale environments, and have to set certain
>> connections/plugins/defaults etc etc
>> Regards,
>> Richard
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190619/4a275d2a/attachment.html>
