[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Nyall Dawson nyall.dawson at gmail.com
Sun Jun 23 16:33:13 PDT 2019
On Sat, 22 Jun 2019 at 16:55, Rainer Hurling <rhurlin at gwdg.de> wrote:
> As the maintainer of the QGIS port for FreeBSD, I am preparing a port
> for the recent update to QGIS 3.8.0.
> This seems to happen since #18fb3f2 [1] (committed 2019-05-13, submitted
> 2019-04-30). Before the commit, the build process takes a normal
> duration on FreeBSD.
> As far as I can say, the problem occurs with both proj-5.1.0 and
> proj-6.1.0. GDAL version is 2.4.1, the OS is FreeBSD 13-0 CURRENT amd64.
Hmm - perplexing. Most of that commit should be ifdefed out for proj <
6 builds. I wonder if you tried trimming the contents of
qgscoordinatereferencesystem_legacy.h to just a couple of sample lines
as a test? Maybe there's something in the compiler which doesn't like
the large static QMap...
Nyall
More information about the QGIS-Developer mailing list
