[QGIS-Developer] [Qgis-community-team] QGIS documentation build is failing and is making me crazy. Heeellp!!!!
DelazJ delazj at gmail.com
Tue Jun 25 07:19:56 PDT 2019
Hi Alex,
Thanks for checking
Le mar. 25 juin 2019 à 16:02, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Hi,
> I have tried locally, and I got no failures on the 51 tests.
> There error is:
> Document: docs/pyqgis_developer_cookbook/cheat_sheet
> Application path not initialized
> File "docs/pyqgis_developer_cookbook/cheat_sheet.rst", line 297, in default
> Failed example:
>     layers_names = []
>     for layer in QgsProject.instance().mapLayers().values():
>         layers_names.append(layer.name())
>     print("layers TOC = {}".format(layers_names))
> Expected:
>     layers TOC = ['layer name you like']
> Got:
>     layers TOC = ['Companies', 'layer name you like']
> File "docs/pyqgis_developer_cookbook/cheat_sheet.rst", line 327, in default
> Failed example:
>     layers_names = [layer.name() for layer in QgsProject.instance().mapLayers().values()]
> Expected:
> Got:
> It seems that the 'Companies' layer is added to the TOC in
> https://github.com/qgis/QGIS-Documentation/blob/6234bdcece8d5d94eb5acf7802dac13b289d65db/source/docs/pyqgis_developer_cookbook/expressions.rst#L151
> I bet the reason why sometimes it fails, and sometimes it doesn't is
> because doctest may not always follow the same order. Since we only want to
> test RST by RST, I think we should do some kind of sanitization at the end
> of each file.
> How do we do this sanitization?
In the commit you mention, which aimed to fix that issue (PR with
discussion at https://github.com/qgis/QGIS-Documentation/pull/3869), I put
the codes in a .. testcode:: group, thinking that will bound the
'Companies' layer creation to that group only. Obviously a fail (though the
build succeeded locally and failed on travis the first time before
succeeding two times after close/reopen steps).
What's the purpose of group, then (
https://www.sphinx-doc.org/en/master/usage/extensions/doctest.html)?
The order of doctest may indeed be random since providing the suggested fix
also fails (https://github.com/qgis/QGIS-Documentation/pull/3880) with
suggesting the current situation. :mad:
Harrissou
> Alex
> On Tue, Jun 25, 2019 at 11:58 AM DelazJ <delazj at gmail.com> wrote:
>> Hi,
>> For days now, master in QGIS-Documentation is failing [0]. For the same
>> reason, which has nothing to do with the writing system but the testing
>> framework for pyQGIS code. Issue is that the failure does not seeem to be
>> constantly reproducible.
>> In the link above, havatv-climbalongline and havatv-pointtolayer are both
>> based on master HEAD and none provides changes to code testing. One is
>> passing and the other one is failing. Actually both are reported failing in
>> doc repository [1]
>> The fixFailingTest2 branch, also based on master, provides a fix based on
>> the suggestion in Travis message. But it failed, and the suggested solution
>> would be ..... the current master state.
>> I'm getting crazy so if someone wants to give it a look and bring the
>> repository to green, it would be nice.
>> [0] https://travis-ci.org/qgis/QGIS-Documentation/branches
>> [1]
>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+sort%3Aupdated-desc
>> Thanks,
>> Harrissou
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190625/5349f9b4/attachment-0001.html>
More information about the QGIS-Developer mailing list
